Results 11 to 20 of 27
January 17th, 2005 03:08 PM #11
gas pang alis sa adhesives but im not sure if its safe sa dashboards...
January 17th, 2005 03:20 PM #12
On velcro tape.. how do you stick one side of velcro tape to the dashboard and the other side on the dashield? Isn't double sided tape (3M) is the most practicle for dashboard and permanent adhesive to dashield. So back to question number 1 again. What adhesive to use for dashboard.
On removal of sticky adhesive remnants on dashboard i suggest remove those grime using cloth rug soak in hot water. This is the way to remove stickers too.
January 17th, 2005 03:28 PM #13
sagwa nga tignan ang dashield na di pulido ang dikit...ako ang ginawa ko,linis with soap and water,then pinalitan ng 3m moulding tape...pagkakabit,i put weights on it..(hollow block plates wrapped in plastic)mga 2-3 days,ayus!..un nga lang talagng may parte ng di sagad(lalo na kung pre-made na ung dashield)..wala na ka magagawa dito..
hope this helps..
January 17th, 2005 03:41 PM #14
Use 3M adhesive remover. Available at SM Hardware section. P184.75 per spray can.
January 17th, 2005 03:48 PM #15Originally Posted by Field Master
theveed suggested the velcro tapes for the dash sheild for the reason that with velcro tapes, from time to time you can remove the dash sheild and wipe off the dust accumulating over time under the dash sheild.
problem with double adhesive tapes, in time the adhesive will dry out and leave a mark on you dash board which becomes permanent . So you're forever stuck with your dash sheild
January 17th, 2005 06:18 PM #16
langyang dashshield yan, madami ng napeke yan ah. isa na ako dyan dun sa aking previous car.... its either that na sobrang nakadikit sya or it does not stick at all.
January 17th, 2005 06:23 PM #17
useful cguro to para sa mga palagi nakapark under direct sunlight..but it makes the car's dash look like sa mga taxi, maraming abubot but pangit sa taxi kc corduroy ata karamihan hehehe imo lng naman
- Oct 2004
- 3
January 18th, 2005 11:49 AM #18thanks for the replies! i'll try all the suggestions you guys made except for the gas which i already tried on a small patch of the dashboard. natatangal nga pero namumuti. will let you know about the final results.
- Aug 2006
- 4
January 15th, 2007 12:30 PM #19Bro i suggest that you go to the dashield main office, and dun mo ireklamo cuz far as i know may lifetime warranty yan. Along Edsa if you're south bound after shell station sya sa proj.7 halos katapat ng sm annex sila rin gumagawa ng shark
step boards and so on...
January 15th, 2007 12:53 PM #20
Monk-owned R53
