i plan to replace the airfilter and fuel filter sa labas muna. pag di parin nakuha saka ko pacheck sa computer. pde kaya madumi rin nozzle?
Change Oil, Oil/Fuel filter at air filter muna palitan niyo sir. Mas mura pa parts as Seiring,Good Gear at Fronte at pwede pagawa sa mga suking mechanic niyo. Then observe niyo muna po kung may improvement sa FC.
Also pa check niyo na din po Camber and Alignment. AFAIK pag out of spec na yung Camber at Toe settings eh additional load din sa makina yun plus uneven tire wear. Sakit din usually ng SF yung Negative Camber sa harap.
replaced my airfilter and fuelfilter cost 2k including labor sa fronte. definitely nag improve performance. ill be monitoring the fuel consumption.
parang ganun parin fuel consumption ko my 500 pesos(42.05/lit diesel) runs around 70kms only. san kaya problem nito? ok naman power and di naman mausok
Hi guys/gals, may available pair of rear foglamps for SF2?
Just pm / call or text me for anyone interested. Tnx.
Posted via Tsikot Mobile App
Perhaps it has to do with your route? Constant stop and go traffic and short trips are very detrimental to our FC. Our SF drinks at the vicinity of 7km/L as well, according to the MID at least (13-15L/100km) Haven't tried the full tank method yet. But then again, our previous 08 SF 4x2 got similar FC numbers too.
Sent from my GT-I9100 using Tapatalk 2
thanks for the reply. i hope its normal. btw do you have a tip. how to improve 2nd row aircon vents. parang mahina yung air na lumalabas dun. TIA
btw my SF 07 is due to registration this month. pano ba makukuha engine number nito. do i need to remove the battery, batt holder and airfilter cover?
Air intake hose na nandun sa may grille lang kailangan tanggalin. Then kailangan medyo contortionist yung mag stencil hehe. Kapa kapa system na. Ewan ko ba sa hyundai/kia. Yung mga engine numbers nila sobrang hirap ma stencil.
question po mga master. is it normal?
1. notice ko while accelerating from stop. naririnig ko high pitch sound like from turbo. (done this while my window is open) me air leak kaya?
2. when driving for mga 1hr. when i remove dipstick or oilcap while idling me smoke na lumalabas. any thoughts? thanks!
I'm about to register my Santa Fe; how much did you pay for LTO registration?
* sir parakito ,
ask ko lang if you have any idea if how much yung side mirror with led signal sa mirror with side repeater like the 2010 models , to be used on 2008 model ?
if assembly yung papalitan is it already body coloured?
* sir parakito ,
Mga boss i have concern with my 2007 2w a/t SF, di na nag eengage yung drive. I mean, kahit ilagay mo sa D, walang nangyayari. Dati, paminsan minsan lng, but ngayon kahit moving ako at 100 kph, buglang nawawala. Pero yung reverse okay nmn except, kahit di ko apakan yung brake pedal, pwedeng ilagay sa R.
Nong una sabi, kulang lang yung transmission fluid. So pinachange oil ko at pinalinisan lahat pati yung parang strainer. Then may pinabiling spray para daw panlinis ng linya.pati fuel filter pinatingnan ko na rin.
Also, pag stationary lng yung SF, aapakan ko yung brake going for D, iba yung tunog. Parang may kalabog sa ilalim. Parang di nakaapak sa preno dahil pilit yung pagkapasok.
Kanina, pinatow ko na. Baka alam nyo pano mga sir.
Thanks
Sir pa check nyo ang switch ng valve body at transmission range
Tsikot Mobile App
Hi, noob member here. I am considering purchasing an 06/07 Santa Fe V6. Are there any V6 owners here? I'ld really like to get some info regarding this model, whether good and/or bad. Any feedback will be greatly appreciated. Thanks in advance peeps!
