Originally Posted by
emonem
Good day sir,
I have been a proud owner of 2010 spec up Sta Fe for more than a year. I also wrote a review on this forum about a year ago. Sadly just after a year of using my unit I experienced transmission problem, i have it checked with my casa. After they run diagnostic on it, it reads "TRANSMISSION RANGE CIRCUIT MALFUNCTION"
Base on the mechanic they said that when shifting from normal to drive the gear will go directly to 3rd gear instead of 1st gear. Every time you shift from neutral to drive you will experience a violent shift shock that literally shakes the whole engine block and body.
I did not do any upgrade or modification and the unit is casa maintained.
Did anyone experienced similar problems or aware of similar cases?
Anyone knows someone from HARI that i can talk to regarding the built quality of the unit?
My father and father in law was planning to buy a sta fe for themselves but they were literally turned off with what happened to my unit...
need your replies sirs...
thanks
