Page 6 of 240 FirstFirst ... 23456789101656106 ... LastLast
Results 101 to 120 of 4793
    Mar 2012
    #101
    Quote Originally Posted by b0y37 View Post
    Looks good, torquey engine. Sana ok din ang handling.
    Hmm..madami na namang sasakit ang ulo nito. Lancer EX or ito? haha
    Yan nga dillema ko sa ngayon eh. hehe For you, which would you choose?
    #102
    Quote Originally Posted by Rockyds View Post
    Tingnan ko muna yung actual unit. Iba rin kasi ang dating ng itsura ng EX. Pero performance and FC-wise, mukhang panalo ito.
    Jul 2011
    #103
    sir hintayin mo na tapos saka mo i-compare para walang pag-sisisi. unless kailangan mo na talaga ng kotse.
    Mar 2012
    #104
    Quote Originally Posted by s10pao View Post
    Hindi naman super kelangan, kating kati lang makakuha na. Hirap labanan! haha
    BTW, kung sa power or speed or kung anuman tawag jan (sorry noob ako sa mga sasakyan hehe), which is better in terms of the mentioned? EX 1.6 GLX M/T or etong Accent CRDI (say yung 1.6 M/T variant din)?
    Sep 2012
    #105
    Mas malakas malamang ang Accent CRDi..
    Im an owner of previous Accent CRDi 1.5 and kaya nya makipagsabayan sa 1.8 Civic
    #106
    Quote Originally Posted by Dexdrex View Post
    yung 1.1 nga na i10 kinakaya yung 1.8 Civic
    [ame=http://www.youtube.com/watch?v=X5IBNIuNKTA]CIVIC 1.8 VS Hyundai i10 1.1 - YouTube[/ame]
    Mar 2012
    #107
    Ang Hyundai i10 ba CRDI din at may turbo? hehe
    #108
    As far as our info sa dealership the accent CRDI will come out soon. Hopefully by the end of the year but we're still not sure. But we were already given the go signal to accept orders. the price quoted earlier seems about right but its better to wait for the actual announcement of the price. HARI likes to surprise everyone of the actual arrival of our new models As for the engine if it has a turbo im not yet sure but other sites say it has a turbo although i cannot confirm that.
    #109
    During my test drive...
    Handling is what you would find in the Accent sedan... not much different.
    The power from the CRDi engine is kinda .... bitin. The engine pulls good initially then power quickly drops off.
    As for the looks, I am not really sold on the styling. The hatch portion feels just "off" as compared to the rest of the car.
    #110
    Sir GH, I posted several months ago where I asked a comparo between the FF TDCI MT and an Accent CRDI given a 700-800k budget. So, iba pa rin talaga ang "feel" at hatak ng Focus, given na 1.6 na yung sa Accent?
    About the hatch portion.. I agree. Parang tinapyas yung likod nya at first glance kya it looks "off", hindi kasi halata yung contours. Maybe it looks good in person, though.
    #111
    The Ford Focus TDCi in either MT or AT has much more "hatak" and goes all the way to the redline, which is satisfying to drive aggressively.
    I was expecting a bit more from the Accent CDRi, Even mentally compensating for the smaller displacement, the power range simply feels too short. You'll end up having to shift much earlier.
    #112
    Correct me guys if im wrong. I think this is because of the different turbos used. Ford uses a traditional turbo charger that needs to spool up while Accent uses a VGT which allows you to get a certain turbo boost even on low revs. VGT doest spool up thus the term variable geometry allowing boosting in low aspect ratios. You will thus feel a better boost on Ford on as revs get higher while Accent starts its turbo boost even on low revs kaya di masyado ramdam pag mataas n rev mo kasi nung mababa palang may boost na.
    Mar 2012
    #113
    Quote Originally Posted by njgarin View Post
    So may possibility pala na hindi nakaturbo ito? Hmm
  14. #114
    I don't think so. Even the old accent 1.5's have VGT turbos. Good luck na lang kung walang turbo. N/A na 1.6 common rail diesel? Sure sobrang matipid but you'll get roughly 110Nm of torque and very very low horsepower (in the 55-65's hp range).
    #115
    A VGT will let you have boost at a low RPM and keep it until a high rpm. This should result in an engine with a very wide power band. BUT in the case of my experience driving the Accent CRDi, the powerband is pretty narrow and ends too early.
    #116
    VGT na rin ang Focus
    #117
    Did some research from the internet. Naka VGT sya
    #118
    Tsaka 2.0 ang turbo diesel ng focus sir 1.6 lang ang sa accent. hyundai U2 Diesel Engines with a displacement of 2.0L w/ VGT is incomparable to the 1.6 VGT having a power difference of 40 HP (130+ for the Accent vs 177 for the 2.0 R-eVGT of the Tucson). Its like comparing David vs Goliath ehehehehehe. The better comparison to the Focus is the Elantra since they are on the same segments. Ang ka segment ng Accent is the Fiesta. Kung sa ford comparison mismo you would'nt compare a fiesta to a focus on terms on engine performance right?
    #119
    Its not VGT sir. Its TDCI. Its a conventional turbo diesel. baka nalito ka dun sa bago sir. yung VCT. Variable Cam Timing yun hindi turbo. The newer version of Focus yung 2013 wala pang diesel variant puro gas. Wait and see pa kung may diesel na lalabas yun. But anyway like i said earlier we really cannot compare the 2 cars since they are on different segments. the focus is around 1.1M while the accent will be around 700-800 depending on transmission. See the difference?
    #120
    By our own Sir Niky
    Welcome to Bigbigcar.com
    There’s a good reason for the Focus’s tagline “Surprisingly Fast”. It’s because it is. The gasoline engine’s performance can best be described as merely adequate, but the TDCi’s variable geometry turbo allows it to spool up fast and punch hard. There’s a bit of electronic throttle lag when you press down on the accelerator pedal, but once it goes, it goes. In traffic, the TDCi has enough grunt to leave its gasoline-fed competitors behind in a huff of diesel fumes.
Hyundai ACCENT Hatch CRDI 1.6
