UNDERCHASSIS INJECTION RESTORATION
may nakapag try na nito?
personally, the only reason i'd resort to this, is because there are no replacement parts available.
originals are always better than rebuilts..
last thursday punta kami ng family ko sa sm north, pag uwi try ko ibirit ng 120kmh...yakang yaka!
sarap talaga gamitin ng GS TCI namin, di pa na blank egr nyan:superman:
Offroad lights naman yan sir, madami masisilaw sa iyo nyan. I saw that already on a strada, di rin maganda buga ng ilaw kahit na 55 watts pa per lamp. Nasa roof kasi kaya silaw din ang kasalubong mo. Kung ayaw mo pa retrofit ng projectors+hid yung head lights mo stealth install ka na lang ng led bar spot lamps or led projectors behind the grill.
* sir IMm29 & yebo...tanx po sa mga advise nyo, nakita ko lang po yan sa fb acct. ng S4S AUTOHUB..
gusto ko po talaga palagyan ng foglamp GS TCI nmin, kaya po naghahanap ako kung ano maganda
at tanx po talaga sa mga tsikoteers na tulad nyo at least nagkakaroon ako ng idea..
Our ride is nearing 25KKm..... Time for another PMS/ oil change....
22.9K:toma:
*skyflakes,
Hingi ka na lang ng referral kay yebo kung san niya pinagawa yung H/L ng BT-50 niya. For sure mas maliwanag na yun vs stock. Plus mapapakinabangan ko pa din naman ang high beam mo, pero magiging quad na ang high beams.
If you can find a good location for a LED bar on the GS fascia, I'm all ears too. I'd seen one of those 32" led bars and bastos talaga sila. Nga lang, since major glare for oncoming motorists, if you're considerate, you'd probably keep them off most of the time. Sayang lang din. Perhaps the smaller ones are bright enough without being too glaring.
Eto, 20w LED. Would be good auxiliary lighting for the GS. If you could make it fit somehow.
LED (fogs) off:
LED (fogs) on:
