Page 44 of 65 FirstFirst ... 3440414243444546474854 ... LastLast
Results 861 to 880 of 1294
    Dec 2011
    #861
    Quote Originally Posted by dakilang.kamao View Post
    Any cons of running 205/50/16's?
    that is a significant increase in the overall circumference of the wheel which will definitely affect your speedo and Odomoter reading. My experience with my previous car is that it will cause your odometer to read lower by at least 10% (example is if you run an actual distance of 99 kms the reading would only be around 90 kms). anybody please correct me if you find this posting erroneous as it was my observation from my previous car.
    Feb 2012
    #862
    Hi mga sir, newbie here. San po maganda mag pa leather seats within makati/pasig area? And how much kaya abutin? Thanks
    Oct 2007
    #863
    good day.
    choosing bet 16 and 17 mags. friend of mine told me that mas mahal ang gulong ng 16? and ang ride nman daw ng 16/195/50 is same as 17/45? tamo po ba? btw. im not going to install a lowering spring and the likes. many thanks
    Jan 2012
    #864
    Not a fan of LED's. Just stick to filament bulbs/HID's for easier modifications.
    i already have 6k hid and white led park lights, just think this would be a nice twist for the accent since i have no fogs yet eh
    Jan 2012
    #865
    Quote Originally Posted by maxhedrum View Post
    fake na kung fake...hehehe btw, saan ba nagsimula thinking na "ricey" . tingin ko kasi sa kotse parang damit, kung ano maganda dating sa mata mo eh wala na ako paki sa sinasabi ng iba.
    btw, I just installed Philips Xtreme Vision....bought it for 2,200K (ouch, mas mura sa banawe pero no time) at one of the car shops beside Alabang Town Center. Pag gabi kasi para akong bulag mag-drive dahil sa tint ko. Pero after magkabit, lumiwanag na. Masarap na mag driver pag gabi.
    hi naka HID kasi ako and then i heard about the philips xtreme vision so i wanted to try it sana
    questions lang
    1. how do you install it? papalitan lang ba yung bulbs then yun na? pano yung mga watts etc..?
    2. is it white in color? or still yellow
    3. mavvoid ba warranty? kasi pag ballasts hid plug and play kaya hindi mavvoid thank you
    i heard kasi na wala na syang glare. eh kawawa naman pag naka hid tapos not retrofitted kaya wanna try this out sana thank you!
    Apr 2006
    #866
    [QUOTE=meikey;1874265]wag na sir..
    ito ba mags na nakuha mo? hehehehe, this is what I also wanted sana to get...
    heheheh, ito sana bibilhin kasi nakabili na ako ng springs. But I ordered a Mixed offset for this, +42 on front, +38 on rear. +38 kasi tingin ko tatama na sa fender lining yong gulong pag may pasahero sa rear. nakuha kong springs, 35mm drop. it's around 2 finger gap siguro...
    But kung ako sa 'yo, Lowering springs na lang, tapos pa negative camber mo ng konti. Oh di aggressive na aggressive na yong accent mo.. Yon nga lang, patay tayo sa maintenance ng gulong. Because if you set your camber to negative, it is certain that you'll have an uneven tire wear..[/QUOTE
    Correct me if I'm wrong. AFAIK kung mas positive ang mags then mas pasok siya sa loob kaya di sasayad sa fender. so the +38 offset would bring the mags more towards the fender area kaya mas sasayad. dapat siguro +42 or more para sa likod para pasok sa fender.
    Feb 2012
    #867
    Quote Originally Posted by bg32 View Post
    sir how much po HID?easy to install po ba? post nmn po ng pic..tnx
    Jan 2012
    #868
    Quote Originally Posted by walds View Post
    yup 4300php bi xenon hid hi and low na 6000kelvin and then plug and play lang siya with ballasts
    Nov 2011
    #869
    Quote Originally Posted by paolo_d View Post
    noob question,
    ok lang ba sa casa kung ipa-body color ko yung door handle? di ko trip yung black...white pa naman yung kotse
    nagtanong na ako sa casa before, sabi cover lang daw ang pwede ilagay. Mas maganda nga sana kung body color yung door handle.. pls share guys kung may alam kayo re this..
    Nov 2011
    #870
    How much pala door visor for accent? 2,500 ang quote sa akin ng casa.
    Jun 2011
    #871
    Quote Originally Posted by raffy_here2011 View Post
    800 lng yan sa banawe.
    Nov 2011
    #872
    Quote Originally Posted by markangelo_m View Post
    thanks sir markangelo! libre ba pa-install dun ng visor? may availalble mud guard din kaya dun sa banawe? honestly di pa ako nakakarating dun. puro manila lang ako..
    #873
    sa MASPRO sir halos andun lahat ng kailangan mo sa iyong accent, look for sir benjie. presyo nya kasama na installation, ok kausap yan si sir benjie pwede din humirit ng discount lalo na kung dami ka nabili sa kanya.
    Nov 2007
    #874
    pwedeng pwede nyo po yan pa body color sir.
    But, para pulido ang pagkatrabaho, tanggalin mo yong handles, w/c definitely sa case ng accent, you need to remove the door trims to access the mounting bolts.
    Jan 2012
    #875
    Quote Originally Posted by voltey09 View Post
    Seriously? Using the online tire size calculator, it only shows a 1.8% difference for the speedometer reading -- that I understand; as far as odometer reading, I don't get how tire size would be affected since it measures distance.
    I'm simply wondering if I'd have any issues with the wheels hitting the fender line at any point.
    Feb 2012
    #876
    sa seatmate pre maganda daw. nagpaquote ako last week 6500 php daw yung leather seats.
    Feb 2012
    #877
    mga sirs, any suggestion po para sa horns ng accent. gusto ko kze yung malakas... may mga nakita ako na youtube, pero mas maganda kung may suggestions from the experts.
    [ame=http://www.youtube.com/watch?v=NcL0b-vzsCc&feature=related]EvoX PIAA SUPERIOR BASS HORN - YouTube[/ame]
    Oct 2004
    #878
    The odometer measures distance by wheel rotation, there is lesser wheel rotation on a larger wheel/tire combo than stock traveling the same distance. Hence odometer readings are also affected.
    Nov 2011
    #879
    Quote Originally Posted by meikey View Post
    thank you sir meikey.. magikot ako sa banawe to check kung may gumagawa ng ganito dun..
    Nov 2011
    #880
    guys would you know kung meron ngang accent gold? may mga nakikita kasi ako na may gold emblem. i dnt know kung nilagay lang. (saan kaya nakakabili ng gold emblem)
2011 Hyundai Accent Modification/ Accessories made
