Page 65 of 65 FirstFirst ... 15556162636465
Results 1,281 to 1,294 of 1294
    Jul 2015
    #1281
    Quote Originally Posted by meggieboy View Post
    Attachment 31798
    I just wanted to share mine
    Sir anong size ng tyre at mags nyo?
    Sep 2016
    #1282
    Hi do you guys think compatible naman yung 205 45 r17 sa accent hatch natin? Plan ko kunin yung stock oems ng rio na 17. Thanks!
    Oct 2016
    #1283
    Hi mga Sir, ask ko lang sana kung saan pwde magpakabit ng:
    1. Touchscreen navigation/GPS/backsensor with camera
    2. Autolock/alarm
    Nag inquire ako sa dealer (which is Quezon Ave.) sabi nasa 53k ang Touchscreen navigation/GPS/backsensor with camera then nasa 8,500 naman yung autolock/alarm.
    Sabi niya pwde naman daw kami dumeretso sa supplier para makamura ako ng mga 15k, sabi niya hndi naman daw ma void warranty pag nagdirect kami sa supplier.
    What do you think po mag direct ako sa supplier or mismo sa CASA nalang? Thanks in advance
    Regards,
    Rodzky
    Jun 2012
    #1284
    Quote Originally Posted by rodzky View Post
    2. Autolock/alarm
    Regards,
    Rodzky
    Direct. Or sa iba pang banawe shops na magaling. Tubong lugaw ang mga casang yan
    Sent from my SM-N930F using Tapatalk
    Oct 2016
    #1285
    Quote Originally Posted by dct View Post
    So mag direct nalang ako sa supplier? Thanks boss dct
    #1286
    Quote Originally Posted by glennhmd View Post
    I have done an EGR block the first week i got my nissan navara (the very first mod i made on it) and six years down the road and my navara still pulls and punches like a sledge hammer. No mechanical problems thus far.
    Has anyone done an EGR blanking mod on the hyundai accent CRDI? how easy or difficult would it be to do on a CRDI accent (it was very easy to do on the navara)? any long-term observations for those with EGR blanking mods out there?
    i also want to put blocking plate on my EGR but i read somewhere that it will cause the engine light to come out. instead i just put OCC on it.
    #1287
    Quote Originally Posted by ketchup21 View Post
    Compatible yan chief pero expect na mapupunit yung fender liner mo at the slightest chance na lumuwag sila. Guaranteed din na may fender rub with 45 series using the same offset as the original. To be safe, go with 205/40 kung may mahanap ka. First-hand experience with 215/45 and 205/45. Inaantay ko na lang mapudpod to replace yung fender liners kasabay ng goma.
    2. Autolock/alarm
    Regards,
    Rodzky
    I'd recommend maghanap na lang po kayo ng reputable na electrician / direct. Yung unang head unit ko sa casa ko rin pinapalit for fear of voiding warranty, pinagii-splice pa yung wire samantalang may adaptor na kasama yung touchscreen para plug and play na lang yung kabit ng wiring sana.
    #1288
    Quote Originally Posted by alrorskyz View Post
    Why You Should NOT Remove Your EGR Valve! - YouTube
    Sent from my SM-G920F using Tsikot Forums mobile app
    Dec 2014
    #1289
    Mga sir, may nakapagpalit na ba ng car horn with piaa superior bass horn? Kinailangan ba gumamit ng relay? Or plug and play lang sya?
    Sent from my LG-H860 using Tapatalk
    Jan 2020
    #1290
    Kailangan bang maglagay ng relay kung magpapakabit ng fog light? Or pwede na ba yung sa may headlight stick sa likod ng steering wheel kung may provision na ba dun para sa fog light? Salamat sa sasagot in advance
    #1291
    Quote Originally Posted by bcharles20 View Post
    Kailangan. Pwede rin gamitin yung abang na fog-light harness sa tabi ng headlight, lalagyan mo nalang ng fuse at relay sa fuse box. Kung OEM fogs kit ang ikakabit mo usually may kasamang switch at instructions kung paano install. Kung sarili kabit mo lang at lalampas kasa factory wattage, need mo run separate wiring, fuse, and relay na pasok sa amperahe ng bulbs.
    Jan 2020
    #1292
    Thanks sa information mo. God bless
    Sent from my CPH1903 using Tapatalk
    Sep 2020
    #1293
    Need help po para mapagana un foglamp, kasi nakabili ako ng stalk switch, problem is need ko pa mag wiring.
    Sent from my SM-N975F using Tsikot Forums mobile app
    Sep 2020
    #1294
    Quote Originally Posted by batang_raon14 View Post
    Weekend DIY
    Paano niyo po ito napagana. ? Foglight?
2011 Hyundai Accent Modification/ Accessories made
