Page 15 of 16 FirstFirst ... 5111213141516 LastLast
Results 281 to 300 of 1294
    Quote Originally Posted by nowitzki41 View Post
    28 yung mags sir, yung tire nasa 13
    hi nowitzki41
    upload ko pics ng accent ko kapag nabili ko na 17" mags ko. hehe,
    hi nowitzki41
    Dec 2014
    Quote Originally Posted by ajec View Post
    hi nowitzki41
    Sige sir! 40 or 45 kunin mo?
    egr blanking
    *zix
    Judging from the wheel gap that could be running on 18 inch. Wheel gap of the Accent on 215/45/17 (my setup) is already a tight fit as it is on stock. Di ko na ginawang 18 dahil takot ko sasayad na ang likod pag may pasahero, at sasayad naman na sa kabig ang sa harap.
    FYI, you'll miss the comfort of the 175/70/14 stock wheels once you upgrade. Nakakamiss. Promise. Kahit mas maganda handling ngayon sa kurbada. 'Yun lang talaga... Di ko rin natiis ang mas malapad at mas malaking mags at wheels.
    Dec 2014
    Quote Originally Posted by batang_raon14 View Post
    Kasha pala yung 215/45/17 sa accent. Hindi ba sya nakalabas sa fender sir? Sakin kasi 205 lang. Parang tatama na kasi yung fender sa gulong lalo na sa likod kapag nagkapasahero na eh. Yung 205 parang sakto lang, pasok parin yung gulong sa loob.
    Dec 2014
    Mga sir, may nakapaginstall na ba sainyo ng strut bar sa harap? Beneficial ba talaga yun at ramdam talaga difference especially when cornering? May kakilala kasi ako nagpalagay. Sabi nya parang mas naging stiff na yung handling at hindi na "dumudulas" yung sasakyan sa likuan. Gusto ko sana makuha mga opinions nyo mga sir. Thanks!
    Sep 2013
    Posting this for interested owners....DRL for Hyundai Accent. Sample unit namin to so binibigay namin at a cheaper price kung sakaling magfit and no problems magiging regular price na. 5500 promo price, 6000 regular price. This does not include the foglights itself, so kung walang foglights nakakabit sa unit niyo ang gagana lang is DRL. Contact me at 09185353975.
    Lower half ng wheel ang nakalabas ng onti, pero yung sa upper half (leading to the fender) suwerte naman at pasok pa.
    For corners beneficial talaga. Caveat lang eh dagdag pa lalo sa tagtag at may impact din sa overall lifespan ng suspension parts.
    Dec 2014
    So parang slightly nakanegative camber gulong natin? Parang yun lang napansin ko sakin eh. Lalo na sa likod. Slight lang talaga. Unlike sa mga vios at city na direcho talaga yung mga gulong kapag tinitignan ko. Not sure kung ganon nga talaga setup nila
    Di ko lang masabi yung sa likod bro kasi di siya kina-camber. Pero bago ako magpalit baliktad naman situation natin sa harap (positive camber naman sa akin nung chineck sa tire supply).
    Dec 2014
    Ah oo nga, nakafix nga yung sa likod at hindi kina-camber. What i mean is yung stance lang nya yung parang slightly nakanegative. Check ko nalang din siguro yung accent ng pinsan ko kung ganon nga talaga. Hehehe! Thanks sir!
    Di naman ma void warranty. You can go up to 17 or 18, basta up to spec ang overall diameter ng tires, not going beyond 3% of original. 175/70/R14 diameter is 602mm. Maximum diameter mo is 620mm. Although sabi ng Tire Center, si Marika, yung magandang receptionist na ex ko sa panaginip, mahirap saw humanap ng 16's
    Actually yung Hyundai dealer ko advised me they will definitely void the warranty if I go beyond yung listed tire spec sa sticker which is up to 195/50/R16 lang, kahit na alam ko pwede higher.
    Oct 2014
    Quote Originally Posted by Rambus View Post
    I switch mo nalang sa dati sir pag pupunta ka ng casa.
    Malaking hassle naman mag switch pa.
    Apr 2015
    Guys hingi lng ako ng suggestions. Naglagay ako ng isang 12inch subwoofer s koche ko, mlkas sya bumayo tska mgnda tunog nya ksi sealed ung baffle ko. Ngaun, may mga nginig or garalgal na tumutunog s trunk or back seat pg mlkas n ung sound. Ano kya dpt gawin or ilagay? Hyundai accent 2014 sedan low end ung koche ko. Thanks
    Weekend DIY
    Guys, I've set my sights on a set of mags with the following specs:
    15x7.5J
    ET 30
    I plan to pair it with a set of 195/60/15 tires with a with of 7J.
    I chose bigger tires since I really hate scraping the humps in our village. My questions are:
    Will the 7j fit the 7.5j wheels?
    Will it cause any safety issues since I travel the expressways daily
    Will it cause rubbing of the fenders & shock mounts?
    Any inputs will be highly appreciated.
    Feb 2016
    15x7.5J
    ET 30
    I installed 195/50R16 tires with 16x7JJ ET40 alloy wheels on my Accent hatch. Couple of issues: The wheels just barely cleared the brake calipers. Also, the tire side wall extends a bit out of the wheel well so mud gets slung onto the fenders.
    A 7.5 inch width rim is too wide for the cross section width of the tire you plan to use (195 mm or 7.67 inches). Per my research a 6.5 inch rim is the ideal match, but you can stretch it out to 7 inches at most.
2011 Hyundai Accent Modification/ Accessories made
