Page 24 of 86 FirstFirst ... 142021222324252627283474 ... LastLast
Results 461 to 480 of 1710
    Jun 2008
    #461
    Hi mga sir i am from the middle east saudi arabia yung accent ko po ay 2012 hyundai accent RB 1.4 mt i been using 95 octane gas from the beginning no knocking issue hanngang ngayon sobrang tipid po ito 1 full tank ko po nag register sya ng 5.7l / 100km 80-90 lng speed ko RPM between 2.2 to 2.5, 80% highway driving kung sa medyo mabilis 6.0-6.1l /100km 100-110km speed I think my RPM is between 3 to 3.5 80% highway driving using Castrol 10w30 malambot lang yung spring sa likod pero dpa nman sumayad khit puno yung sasakyan i am happy with the accent overall performance sana ma solve na yung knocking issue dyan sa pinas
    Jan 2011
    #462
    Quote Originally Posted by callmenadz View Post
    edi meaning sa fuel nga talaga natin to if ganon?
    added: *miekey and andretti saan ka nag kakarga nang fuel mo?
    ako kase sa caltex lang and always gold lang.
    I have been a regular shell unleaded user, pag wala naman its either XCS or caltex gold.
    Up to now wala naman knocking sound yung akin (2500km + on my ODO)
    Aug 2004
    #463
    We were planning to get an Accent sana for our business as service car. kuha sana ako sa friend ko that works in Hyundai. kaso siya na mismo nagsabi na wag muna bumili,may knocking issue sa engine... daming nagagalit at nagrereklamong customers. oh well... siguro iwas bili muna tayo ngayon nito hanggat di pa nareresolbahan ang issue.
    sa ibang gas models nila like tucson elantra sonata A-ok daw walang problema.
    May 2011
    #464
    out of budget ba ang Elantra?
    May 2011
    #465
    in a few months, ill be ready to get an econo car for my wife. AT most probably and not above 600K. so I am just curious about the status of this knocking issue. i hope you can answer some questions:
    1. at what speed or rpm does this happen?
    2. does the sound come out when you are fixed on a gear or does it happen when the car is changing gears?
    3. does it sound like accidentally shifting in 5th gear instead of 3rd at 60kph when driving a manual?
    thanks in advance.
    Jan 2011
    #466
    Is there any doubt about the fuel quality here?
    The advice is always the same... change stations, change gasoline type. It's especially questionable if the fuel has a lot of ethanol additive whether the advertised octane is correct.
    My recommendation, if you don't want to muck around with reflashes:
    1. Drain your tank. Fill up with V-Power at a trustworthy station. The 96 and 97 RON gasolines of other makers really aren't the same as this gas. Blaze is even better, but some performance car owners actually don't like Blaze because quality differs from station to station. Observe. If no knocking, your car is normal. If it knocks, then there's a problem and your particular unit needs a reflash.
    2. Start going down, go from there to Shell Premium... then down to Unleaded. Pick the cheapest gasoline that doesn't cause knocking. It will likely bet 93-95... and even then, the 93s might not work in hotter weather if the alcohol content evaporates or goes stale... so it may be worth mixing it with V-Power or Blaze (the benefit of blaze is it doesn't rely on ethanol for RON numbers).
    Simple. Easy to do. And it will tell you if the problem is really with your car or with your local stations.
    I can only speak for myself for this one.
    Though I didn't bother to try all fuels, what I did from the start since getting the unit was to use only the recommended fuels.
    Since upto now ala pa knocking issue yung aking unit, its either that I am doing the right thing or just plain lucky with my unit...
    #467
    Quote Originally Posted by andretti View Post
    Sir Andretti, what brand & specific type of fuel do you use? I got my accent today and was told by my SA to use Shell Unleaded. Ok lang din kaya ang Caltex Gold since the station is more accessible from my residence. Thanks.
    #468
    Quote Originally Posted by keck View Post
    I backread and got the answer .. ano po ba RON ng shell unleaded?
    Jan 2011
    #469
    As previously posted, kahit na right fuel ikakarga mo better choose also the gas station locations, yung malinis at di bahain na lugar as much as possible.
    Oct 2004
    #470
    Hmm... Naka sked pa naman ako mag reflash ng ecu, i have to ask my SA regarding the resulting lower engine power after the reflash.
    Aug 2004
    #471
    Quote Originally Posted by wilcats View Post
    Supposedly there was an early issue with the 2.4 and local gasoline. Think it's okay now.
    Apr 2006
    #472
    Quote Originally Posted by jayvel View Post
    si mon din ang SA ko. Ano sa tingin mo bro gagawin natin sa slow response? di naman siys super slow response kaya lang compared before me nagbago talaga e, subukan ko kaya higher octane na fuel?
    bratski, pwede mo naman pa update sa Greenhills yung accent mo a, atsaka sabi sa kin mekaniko lahat daw mg dealer na advise na regarding sa knocking sound kaya cgurado updated na software ng lahat ng dealer
    Guys, I have the same problem. Sometimes pagpalabas ng basement parking e parang ayaw na umakyat ng oto. My ECU was reset, updated, etc 4-6 times na and 1 mechanic told me na palit na ng ECU. Everytime na dinadala ko sa dealer para ipaayos e gnun parin, di naman naayos so baka tama nga yung sinabi ng mechanic na change ECU na. Although, parang ayoko na with all the problems I have been reading about the Accent, so ibabalik ko nalang sa kanila and get a refund or a different unit. Sobrang hassle na spending weekends sa dealer na wala namang results at sasabihin pa sayo na ok na and everything is normal! Grabe ang city fuel consumption ko now is about 6.6-7.5km/Liter! Ano to SUV!
    Mar 2011
    #473
    I was able to talk to my Service adviser over the phone about the slow acceleration response after the ECU reflash and here's how it went.
    ME: Update ko lang kyo about the knock issue with my Accent unit... i don't have the knocking sound anymore after the ECU reset last Monday pero sobrang bagal ng hatak specially from a complete stop and pag paakyat.
    SA: Ganun ba sir? humina rin ba aircon nyo??? (alam na alam ah...)
    ME: Oo dati pwede na saken 1 lang blower with thermostat at 3/4 pero ngyn i have to put it at 2. Tsaka ung fuel consumption ko e hindi acceptable 7.5 - 8 KM/L (considering na off hours ung office ko 2PM - 11PM at EDSA ang daan ko 90% ng byahe)
    SA: (...moments of silence..... ) hmmm.... dalhin nyo na lang dito sir bukas para matignan.
    ME: Ok cge dalhin ko jan bukas.. pero pag dinala ko ba jan bukas may solution kayo?
    SA: (...moments of silence.....) Sir wala pa po e.. wala pa po advise samen tungkol sa on-going issue ng Accent.. (Paktay tyo jan! )
    ME: so wala rn palang ggawin sa unit ko bukas??? cge ddalhin ko na rn bukas para makausap ko na rn kyo about this issue.
    THE END!
    Aug 2011
    #474
    sana di ganyan makuha kong accent....
    Oct 2004
    #475
    Quote Originally Posted by mackyt111 View Post
    Pareho lang tayo ng city consumption pero mas matipid pa nga sayo ng konti. Regarding sa refund mo malabo yan. Although you could be the first. Ganyan talaga in buying an all new model, dami pang bugs and glitches. Mas malaki talaga ang risk.
    Aug 2011
    #476
    Quote Originally Posted by erj22 View Post
    Sir, kung ang ratio ay 5:3 ang chances na may knocking, why get one?
    Sa tingin ko nga sir lahat ng 2011 Accent may knocking problem its just that di lang alam siguro ng owners na meron sila (excluded and mga nag pa update ng ECU na ngayon may low power problem).
    [SIZE=4]Sa mga di pa na update, "huwag kayo magpa-update" I tell you magsisisi kayo.[/SIZE]
    Iwas nalang muna sa Petron, or find the gas station na di binabaha.
    May 2011
    #477
    aw. badtrip naman engine woes. Gising Hyundai!
    Aug 2011
    #478
    Quote Originally Posted by mexophilia View Post
    antay unit na lang ako eh, ma check siguro pag dumating sa 25...
    Oct 2004
    #479
    Sa tingin ko rin nga din na lahat ng 2011 accent may engine knock, hindi kasi laging lumalabas ito at pasulpot sulpot lang. And pag naka on radio mo hindi mo na maririnig. Medyo mahina rin kasi yung sound. Others may not know how to look for it.
    Oct 2008
    #480
    if the sound is similar to 3rd gear shifting to 5th gear, im familar with that sound. so far, no sounds like that coming from my unit. I remember my getz used to have this issue when I'm using unleaded and not premium. nakukuha sya sa timpla ng clutch at gas pero sa premium/xcs di na kailangan ito. could be a design of the hyundai in general on their engines.
    Quote Originally Posted by bratski View Post
2011 Accent AT - Engine Knock!
