Page 508 of 808 FirstFirst ... 408458498504505506507508509510511512518558608 ... LastLast
Results 5,071 to 5,080 of 8077
    #5071
    Quote Originally Posted by cocoy View Post
    ai ganun pala.. wala pala EGR ang D4BH TCI engine.. wow i thought it had one the whole time.. or are you talking about the CRDI engine?
    if ever man mayroon egr valve yan, definitely its mechanical type, controlled by vacuum. even when egr valve breaks down, there is no CEL. effect even better, its like you are blanked. unlike with electronic controlled valve, once it breaks down, CEL na
    #5072
    Quote Originally Posted by zix888 View Post
    Yes bro.,- probably, just like what I have in our TCi GS....
    21.8K:bike3:
    Oct 2004
    #5073
    Unless nagbara while stuck open yung valve? Then loss of power at high rpm
    Oct 2004
    #5074
    Bro zix, assuming pala na nagbara yung Egr ng GS ko, CEL will turn on but performance won't be affected ba?...since naka blank siya right after the Egr valve?
    Sent from my GT-N7000 using Tsikot Forums Mobile App mobile app
    #5075
    Quote Originally Posted by bratski View Post
    correct, if stucked open on tci, greatly affected ang power.
    on your gs case, yes you are right, he only effect will be cel, not on performance
    #5076
    Are these things necessary? Rust proofing? eh di ba rust proofed na ang mga sasakyan pag labas ng factory?
    Sobra naman yan! 17k for rustproofing??? I'm sure pag labas pinagawa yan less than half lang ang gastos mo
    Apr 2012
    #5077
    Quote Originally Posted by ronw123w124 View Post
    Di naman siguro kelangan yan rust proofing na yan.bago pa lumabas ng factory alam ko rust proofed na.
    Engine carbon cleaning - necessary ba talaga to? sa mga sasakyan namin dati wala namang ganyan.
    ugn the rest,mas matipid sa labas. lalo na may pinipirata ako na mekaniko ng hyundai pag day off niya
    #5078
    On rust proofing: isa lang naman ang dapat at least once a year mo i-inspect, yung nasa ilalim ng rubber gasket sa rear door. Kahit anong starex, from the very first model to our beloved GS, e dun ang laging naguumpisa ang kalawang. Yung sa akin 1 year pa lang kinalawang na. Madali lang naman and solution. Clean the area very well (rust and the gunk from the gasket), treat with rust converter, then paint. Di na need pakintabin/buff yung area since natatakpan ng tailgate.
    #5079
    mura yung a/c cleaning if 3k lang tlaga. baka nman papalitan lang a/c filter...
    #5080
    patulong naman gs kdm owners. baka meron po sa inyo may idea magtanggal speed limiter for cvx. max speed is just 110kph. and max speedometer is up to 160 kph only. referred it to the dealer but according to their mechanic ganun daw pag korean unit. many thanks
2008 Hyundai Starex (Gen. 4)
