Page 441 of 808 FirstFirst ... 341391431437438439440441442443444445451491541 ... LastLast
Results 4,401 to 4,410 of 8077
    Aug 2005
    #4401
    Vic, anong oil nilagay ng Hancars noong 1st PMS mo? I can also think the engine oil might be the culprit of the bad FC.
    Ako nag dala ng oil.. I bought it from Seiring.. Yung semi-synthetic nila...
    Jul 2006
    #4402
    Quote Originally Posted by imperialv View Post
    Try to use fully synthetic oil on your next PMS. Motul Specific CRDi or yung Zic RV, you might have a better FC on your GS.
    Jun 2013
    #4403
    Attachment 18823
    yan double contacts pero di naka-on ang brakes.
    also notice that the signal lights and backing lights are reversed. i interchanged the big signal lights and small backing lights and then installed a 55 watt phillips bulb. result is by backing light is now super bright. result, may head light ako sa likod, super liwanag pag umaatras sa gabi.
    How much yung total install and labor?
    #4404
    Quote Originally Posted by rsa527 View Post
    if i remember right, double contacts at maspro was 1.5k with sockets, bulbs and labor included.
    the interchanging of the turn/hazard lights and backing up lights was DIY. ako lang meron nyan sa buong mundo
    #4405
    Actually based on my limited experience in our GS, the 4 sockets for the park lights and brake lights, are designed for double contacts.
    This means that you can assemble 2 double contact sockets from those 4 sockets, by transferring the contacts from the other 2 sockets.
    And, you need to buy only 2 more double contact sockets. (Or, 4 contacts for the other 2 sockets,- if available locally)...
    >>> We bought only 2 more double contact sockets <<<
    19.4K:tomato:
    #4406
    So bro.,- pinag-swap mo ang wiring ng hazard lights at backing up lights?
    Tapos, pinalitan mo ng 55W ang iyong 'bagong' backing up lights (used to be hazard lights)?
    Di ang backing up lights mo ay kulay dilaw?
    Paki-explain naman,- just want to understand...
    (Gusto ko kasing magkaroon ng headlights sa likod para sa mga naninilaw(naka high beam) na kasunod)...
    TIA.
    19.4K:tomato:
    #4407
    and sadly, not mine either hehehe! sabi ko nga, kapag disiplinado paa ko, ayun umaabot ng 12+km/L.
    pero mas malala ka sa akin, di umaabot ng 20,000km ang brake pads mo.
    Yes bro.,- 15KKm lang ang inabot ng front disc pads ko...
    Pero, baka kasi drum brakes ang likod ko...kaya hindi even and brake distribution.... Hindi ko pa napapalitan ang pads ko sa likod...
    Kayo kasi pati likod disc brakes, right?
    19.4K:tomato:
    Apr 2012
    #4408
    Kelan ka ngpa 1K PMS sir? Buti pumayag.
    Jun 2013
    #4409
    Thanks.. When is the best time to go there? At meron ba sila led side mirrors for the GS?
    Aug 2005
    #4410
    Last April lang. May nagsabi na bawal na daw... What if sa HQA ko dalhin, dun pwede ako magdala ng sariling oil d naman nila ma mamonitor yun... Find it weird.
2008 Hyundai Starex (Gen. 4)
