Page 442 of 808 FirstFirst ... 342392432438439440441442443444445446452492542 ... LastLast
Results 4,411 to 4,420 of 8077
    #4411
    Yes bro.,- 15KKm lang ang inabot ng front disc pads ko...
    Pero, baka kasi drum brakes ang likod ko...kaya hindi even and brake distribution.... Hindi ko pa napapalitan ang pads ko sa likod...
    Kayo kasi pati likod disc brakes, right?
    19.4K:tomato:
    Ako 10t kms front brake pads, 15t kms rear brake pads. Hehe!
    #4412
    So bro.,- pinag-swap mo ang wiring ng hazard lights at backing up lights?
    Tapos, pinalitan mo ng 55W ang iyong 'bagong' backing up lights (used to be hazard lights)?
    Di ang backing up lights mo ay kulay dilaw?
    Paki-explain naman,- just want to understand...
    (Gusto ko kasing magkaroon ng headlights sa likod para sa mga naninilaw(naka high beam) na kasunod)...
    TIA.
    19.4K:tomato:
    yup, swapped the backing up lights and turn/hazard lights. white ang backing up lights. check mo yung picture.
    gusto ko nga din gawin na pwede i-ON yung backing up lights manually pero had not had time to do it, madali lang naman by adding an extra switch tapped into the switch on the transmission.
    #4413
    All disc brakes ka bro, di ba?
    I'll checkout tonight bro.,- when I get home... Opis na kasi ako....
    19.4K:tomato:
    #4414
    19.4K:tomato:
    Yes Bro. All discs.
    #4415
    Attachment 18823
    yan double contacts pero di naka-on ang brakes.
    also notice that the signal lights and backing lights are reversed. i interchanged the big signal lights and small backing lights and then installed a 55 watt phillips bulb. result is by backing light is now super bright. result, may head light ako sa likod, super liwanag pag umaatras sa gabi.
    Bro yebo,
    Ano nang bulb yung 55w mo for reverse? H1 ba?
    Jun 2013
    #4416
    Hindi void warranty ng taillight mo bro?
    #4417
    Bro yebo,
    h4 yata, di ko na sure matagal na nainstall yun e, wala pa 3 months after ko nabili ang GS. pinalitan ko yung socket kasi yung original socket e maximum 25 watts lang yata yung bulbs na nakita ko sa banawe. Modified din ng konti yung tail light kasi hindi tapat yung tabs ng socket sa tail light assembly. yun kasi original socket ng signal/hazard lights e peanut bulbs lang, low wattage. so papalitan mo talaga yung socket pag lalagyan mo ng 55 watts.
    Quote Originally Posted by rsa527 View Post
    wala ako pakialam sa warranty, lalo na kung alam ko gawin
    #4418
    Well, definitely iba na talaga ang socket. 55w na yan, pang headlight na talaga! Hehehe! May hi-low din ba? Hehe!
    Ikaw na!
    Jun 2013
    #4419
    I second that! Ikaw na sir yebo!
    Jun 2013
    #4420
    Guys, saan pwede makabili ng HVX na rims?
2008 Hyundai Starex (Gen. 4)
