Guys need help po.. My GS TCI m/T is showing some problems.. Nag sticky ang clutch nya pag natratraffic and naka idle ang engine for a time.. Pero pag. Ok naman ang byahe no problem... Any suggestions po or solutions for this.. 35k palang po milage nya.. And ako lang gumagamit di naman po ako clutch driver.. Ok pa humatak no drag or slide... Pa help po.. thanks
this is new to me... hydraulic clutches should be foolproof..
let's see..
check clutch pedal free play, po.
then there's the clutch assembly inside the housing.. deformed? perished bearing? opening her up is the only solution to me..
perhaps someones out there can provide experiential solution.
let's see..
how come if im not in traffic and the van is moving.. the clutch pedal is operating normally. this problem will start when the van is idle for a time ( i think 15mins ) and im getting stuck in traffic.. and if the problem worsen ill just shut off the engine and let it cool off for an hour.. then it will operate again normally.
is the new starex clutch still the traditional one? or is it now also power-assisted?
if traditional, i'd probably discard the temperature angle. the problem sounds mechanical.
let's see... may tumutukod kaya sa pidal?... is the master cylinder ok? what about the slave cylinder?.. if these are all ok....
i am afraid you might have to open up the transmission housing..
if, however, your trans is cable-operated, i suggest you replace the cable.
sir my GS is a 2012 TCI M/T fluid type sir.. not cable operated. wala naman pong tumutukod sa pedal..
yes sir.. pa check ko .. thanks sir for your replies..very much appreciated
sir paki check ang drive belt & pulley ng alternator baka di umikot ng maayos. nasa rear ng alternator ang vacuum pump para sa hydro-vac ng preno. suspetsa ko dyan ang problema. HTH
sagot ko po para sa brake problem.
ok sir pero sa kabilang forum po.. parang less than ten kaming nakaka experience nung same problem..
thanks sir
thanks sir
Ooh man... Is this sticky clutch problem only experienced on the vgt variant????
Our company ride is tci and our driver has not complained anything similar to this so far....
hehe, mahaba haba ang listahan,, ,, ipapakita ko to sa mekaniko para my guide cla,, kung minsan kasi paisa isa lang kung mag check,,tapos sasabihin obserbahan,pag hinde ok babalik ka nanaman,,malaking tulong tong list atleast wala silang lusot pag nag pa-check,, salamat ng marami sir,,![]()
