Bakit GEN 4 na ang starex ngayon? diba dalawa palang ang body ng STAREX?
Sa wikipedia kasi two generations pa lang?
http://en.wikipedia.org/wiki/Hyundai_Starex
mali naman yung sa wikipedia e. yung 1st gen dun sa wiki e yung millenium series e gen 2 na yun. tapos yung millenium series nya 1997-2007 hehehe!
correct me if i am wrong but,
1st gen 1991-1999 (non-turbo 85hp? may turbo models na din yung later models)
2nd gen millenium series 2000-2003 (turbo intercooler engine 102 hp?)
3rd gen GRX series 2004-2007 (crdi turbo intercooler 145 hp)
4th gen Grand starex series 2008-present (crdi vgt 175 hp)
Yung non-VGT na Grand Starex, same engine with the 2nd gen starex?
i think in australia there's a CRDI grand starex non VGT, but with 6speed manual..
I was reading the old specs of our GS:
For TCi A/T: Gear Ratio : 1- 2.804; 2- 1.531; 3- 1.000; 4- 0.753; Reverse: 2.393; Final Gear Ratio: 3.909
For VGT A/T: Gear Ratio: 1- 3.730; 2- 3.308; 3- 1.519; 4- 1.000; 5- 0.840; Reverse: 2.740; Final Gear Ratio: 2.929
Sa rekta: - final ratio (input to wheel rev)
TCi- 2.943
VGT- 2.460
So, if everything is equal,- ideally,- tipid si VGT ng about 16%.
Further if both are running at 2000RPM and with the circumference of our 215/65 R17 tyres at 2.234meters, then the TCi ground speed would only be at 91KPH, while the VGT ground speed would be at 109KPH.... Sa gearing pa lang ito.... BTW, this checks with my experience on our TCi A/T
17.9K:cupid2:
^add ko lang sir
VGT sa 2500 rpm 140kph, 2800 rpm 160 kph, 3200rpm 180kph. kahapon yan sa sctex, 7 passengers and a weekend of luggage![]()
Walandyo, bro.
Engineer ka,- siyempre may theoretical at actual....
Siyempre,- mas tama ang actual!!! hahaha!
Whew! 180KPH?.... L!ntek,- sa Autobanh lang ako naka-experience ng ganyan + more....Tumatakbo kami ng 220KPH+,- may nagflash pa sa likod para mag-overtake...
At one time, sa motorsiklo pa... Grabe ang kapit/yakap ko sa driver,- pareho pa kaming nakainom (at linsyak,- lalaki pa....)Hindi ko mismo nakita ang speed, pero sabi ng driver about 180KPH daw!!! Lahat ng santo natawag ko na....
17.9K:cupid2:
Yung TCI is hindi pa CRDI, right? So mas matulin pa yung 3rd gen na Starex pala.
Tanong lang, wala bang problema kahit naka 11k KMS na ako? haha
di pa ako ngppa 10K PMS, wala kasing time at naghahakot palipat ng bagong bahay.
