Results 6,561 to 6,570 of 8077
- Apr 2012
- 3,469
July 5th, 2016 06:30 PM #6561What's the solution for sticky sliding door?
Sent from my LG-H818 using Tapatalk
- Jun 2012
- 4,447
- Jun 2012
- 4,447
July 5th, 2016 11:49 PM #6565
July 7th, 2016 10:49 AM #6566
i would not recommend using wd40 or any oil on the rubber gasket of the doors. Oil can cause the rubber to deteriorate.
On the sliding door rails and also on ordinary door hinges i suggest silicone spray lubricant. On the door rubber gaskets just regular cleaning with soap and water. Clean both the rubber gaskets and the area where the gasket seals.
July 7th, 2016 11:12 AM #6567
- Aug 2012
- 2,767
July 7th, 2016 11:53 AM #6568Most people think of WD40 as the usual WD40 Multi-purpose Lubricant. WD40 has multiple products for different materials. They have Contact Cleaner, Engine Degreaser, Silicone Lubricant, White Lithium Grease, etc.
Sent from my D5833 using Tapatalk
- Sep 2015
- 90
July 9th, 2016 03:07 PM #6569sir nawalan din dati power GS ko matic 09, dami kelangan check, atf,fuel filter etc,, pro sakin ang prob pala eh turbo actuator not working sira na diapram, kaya check mo sir ,ganito silipin mo ang turbo actuator na parang turumpo cya sir sa ibabaw ng turbo,pa start mo dapat makita mo na itutulak ng actuator ang lever pababa hangang stopper niya, tapos pa rev mo paulit ulit dapat nag tataas baba cya,,pag hinde o mahina pa check mo na sa expert ang actuator,baka may butas na diapram,kung meron ka hand vacuum pede yun pang test sa actuator,,pati turbo solinoid pa check mo rin,, sana makatulong,,
July 9th, 2016 06:43 PM #6570
Anong alarm ang pwede i-upgrade sa units natin? Di na gumagana ang remote din kse.
Isa pa napansin ko na halos lahat ng door sensor ay sira na. Interior lights don't light up anymore pag open ng sliding doors and passenger door.
Nope Prius had variable speed/inverter Acs since its 2nd generation(~2004)....
A/c
