Results 1 to 10 of 17
- Dec 2010
- 6
February 16th, 2013 03:26 PM #1Hi Guys, I bought a 2nd-hand 2006 Hyundai Starex CRDI 2 years ago. When I bought it the van drove really well and i didn't have a problem with the power. Up until late 2011 when we brought it to Rapide to fix the oil leak we have been noticing. Rapide told us they could do the job. What was supposed to be a P10,000 estimate. Turned out to be a nightmarish P52,000, and still was not able to bring the engine back to its previous state.
Currently, we are having problems starting the engine. We brought the vehicle to several mechanics, only to be disappointed. We have spend another P40,000, changing fuel filter, high pressure fuel pump, etc.. And while it will work for a few days, the problem goes back. Eventually a mechanic told us to pour a cap full of gasoline inside the air intake to jumpstart the engine. We have been doing it for the past 4 months.
I don't want to bring it to just any mechanic, but at the same time i also don't want to bring it to the casa (could be last resort). Does anyone know of a very good Starex mechanic. Please let me know. Thanks
February 16th, 2013 03:51 PM #2
your mistake was bringing it to rapide. i would not be surprised if they were the cause of your engine problems.
go ask a 2nd hand car dealer that sells a GRX. those 2nd hand car dealers have some of the best mechanics around.
- Dec 2010
- 6
February 16th, 2013 04:01 PM #3i know. i was just having regular maintenance check-up done, but decided to have the leak fixed as well. supposedly it was just top gasket replacement, and ended up changing so many other parts. the worst service center ever. they are only good at change oil and wheel alignment
February 17th, 2013 07:18 AM #4
kung nagpalit po ng mga oil seal sa harap tulad po ng camshaft, crankshaft oil seal, ang maaaring isang cause po ay timing, kung nagpalit naman po ng cylinder head gasket tulad po ng nasabi nyo.. eh may loose compression, ibig ko pong sabihin di po maganda ang lapat ng gasket between the cylinder head at engine block... sa mga replacement parts minsan nangyayari po ito
- Jul 2013
- 27
July 29th, 2013 11:32 AM #6
August 1st, 2013 10:38 AM #8
You can observe it while they are servicing your van pa. So you have an idea and visually check kung ano sinasabi nila needs replacement etc.
- Oct 2013
- 2
October 21st, 2013 11:53 AM #10Sir, Is there any good mechanic around las piñas area and know how to fix the starex engine very well? Thank you!
Best bet is along the Rizal Memorial Sports Complex across the site where HP used to be. Yun nga...
Recommended Parking Near De La Salle (Taft)
