Results 1 to 10 of 13
- Jun 2008
- 65
May 24th, 2015 01:23 PM #1pls help give me some points on how to address my problem
di ko po kasi ma open ung honda jazz ko using the car remote key , i don't think sa car remote ung problema kasi umiilaw naman po sya means may battery
pa ung remote
hope to get some advise..tks
- Dec 2012
- 397
May 24th, 2015 03:43 PM #3
Remote ko, after 'round 8 months, ganun din. I just replaced the battery.
- Jun 2008
- 65
- Jun 2008
- 65
May 25th, 2015 12:11 AM #5Replaced battery, still won't open. btw dapat diba may nag bi-blink na light sa loob ng car kapag sarado ang mga pinto at naka lock? Napansin ko walang nagbi-blink. Hindi naman pwedeng busted na ang battery dahil kapapalit ko lng lang January.
- Jan 2011
- 7
May 25th, 2015 12:16 AM #6Maybe its the actuator from the driver side. If you open it using your key and all the doors opened its the actuator on the driver side and need to change.
- Mar 2014
- 901
May 25th, 2015 01:00 AM #7
- Jun 2008
- 65
June 17th, 2015 11:27 PM #8sorry for the l;ate late reply, I just forcibly open it, via hook. ang nakakapagtaka lng e bakit ayaw gumana ng manual key? covered pa ba ito ng casa kahit 4 years na ang unit?
June 17th, 2015 11:34 PM #9
are you sure you haven't exchanged remotes with another jazz/honda car? 3yrs lng usually warranty but if your casa is customer-service oriented they'll fix it for free.
- Oct 2012
- 142
June 18th, 2015 12:16 AM #10Mas maganda kung sa casa mo ipagawa. A few things can go wrong when this problem of yours arise. One or more of the actuators may be stuck or busted or got detached from the lever mechanism. Your remote sensor is failing or it has a drained remote battery. Also check the wires leading to the actuators w/c may have a cut or disrupted line from wear. Check power leads or fuse for the auto entry system. Check if a battery reset by disconnecting the negative terminal for a minute or more will reset the alarm and locks back to function. Good luck!
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
