Results 1 to 13 of 13
    Jun 2008
    pls help give me some points on how to address my problem
    di ko po kasi ma open ung honda jazz ko using the car remote key , i don't think sa car remote ung problema kasi umiilaw naman po sya means may battery
    pa ung remote
    hope to get some advise..tks
    Dec 2012
    Even though there still a light, try replacing the battery first.
    Remote ko, after 'round 8 months, ganun din. I just replaced the battery.
    Jun 2008
    ok ill try
    Jun 2008
    Replaced battery, still won't open. btw dapat diba may nag bi-blink na light sa loob ng car kapag sarado ang mga pinto at naka lock? Napansin ko walang nagbi-blink. Hindi naman pwedeng busted na ang battery dahil kapapalit ko lng lang January.
    Jan 2011
    Maybe its the actuator from the driver side. If you open it using your key and all the doors opened its the actuator on the driver side and need to change.
    Quote Originally Posted by Lutheran View Post
    pa ung remote
    Aftermarket ba ang car alarm at central locks mo?
    Sent from my Starmobile UP+ using Tapatalk
    Jun 2008
    sorry for the l;ate late reply, I just forcibly open it, via hook. ang nakakapagtaka lng e bakit ayaw gumana ng manual key? covered pa ba ito ng casa kahit 4 years na ang unit?
    Jun 2006
    are you sure you haven't exchanged remotes with another jazz/honda car? 3yrs lng usually warranty but if your casa is customer-service oriented they'll fix it for free.
    Mas maganda kung sa casa mo ipagawa. A few things can go wrong when this problem of yours arise. One or more of the actuators may be stuck or busted or got detached from the lever mechanism. Your remote sensor is failing or it has a drained remote battery. Also check the wires leading to the actuators w/c may have a cut or disrupted line from wear. Check power leads or fuse for the auto entry system. Check if a battery reset by disconnecting the negative terminal for a minute or more will reset the alarm and locks back to function. Good luck!
    Jun 2008
    I normally open and close the door by its remote, I never tried opening the door manually until I had that problem. So when this happen again, I have to use the hook method again to open the door. One thing I want to say to Honda cavite. Their service sucks.
    Jul 2012
    bro model ng jazz mo? i had the same issue.. yung bakal ng sa loob ng driverside door ko na nakakabit sa lock natanggal so kahit gamitin yung remote ayaw.. need susi. i just opend the panel then tightened the screw.. ok na ulit.
    Jun 2008
    Jazz Ge 2012,
car won't open using remote control
