Results 1 to 13 of 13
    Quote Originally Posted by Lutheran View Post
    sorry for the l;ate late reply, I just forcibly open it, via hook. ang nakakapagtaka lng e bakit ayaw gumana ng manual key? covered pa ba ito ng casa kahit 4 years na ang unit?
    Mas maganda kung sa casa mo ipagawa. A few things can go wrong when this problem of yours arise. One or more of the actuators may be stuck or busted or got detached from the lever mechanism. Your remote sensor is failing or it has a drained remote battery. Also check the wires leading to the actuators w/c may have a cut or disrupted line from wear. Check power leads or fuse for the auto entry system. Check if a battery reset by disconnecting the negative terminal for a minute or more will reset the alarm and locks back to function. Good luck!
car won't open using remote control
