Page 244 of 743 FirstFirst ... 144194234240241242243244245246247248254294344 ... LastLast
Results 4,861 to 4,880 of 14856
    Nov 2007
    #4861
    Quote Originally Posted by Jecoism View Post
    Just to contribute lang sir wongski, the downsides I can think of with my jazz are these:
    - noisy plastic materials
    Even the top of the line aka the 1.5 a/t does not include:
    - fog lights
    - center console armrest
    - tonneau cover
    - ducktail spoiler
    +1 ako dito,yung fog lights ko oem sa casa 17k ang damage,yung usb hindi daw available eh,tsaka dapat kasama na yung ducktail kaso hindi pa another 8k na naman yun chaka na muna ipon muna ako
    May 2010
    #4862
    noob question lang po.
    kung magpakabit po ng spoiler na hindi oem, mavovoid ba yung warranty?
    Nov 2007
    #4863
    Quote Originally Posted by eph11 View Post
    i think hindi naman
    Mar 2007
    #4864
    Quote Originally Posted by watusi View Post
    pag nakabit ko ito sa GE ko, bubukas na din ba yung cargo light pag bubuksan ko yung ibang ilaw sa loob? ex. pinto sa driver's side?
    thanks benji!
    No problem sir!
    Aug 2010
    #4865
    Guys question naman. Yung pinto kasi sa driver's side tumama sa paso, so yung pinaka gilid nagkaroon ng maliit gasgas. Naalis ko naman totally yung gasgas nya using rubbing compound. Walang katrace trace ng gasgas kaso naging uneven yung kulay ng kapirasong paint. Parang numipis yung paint sa portion na inayos ko. Magkano kaya aabutin ng touch up nito sa casa? Note na mga 1-2 cm lang yung haba ng may uneven na paint at sa pinaka-edge mismo ng pinto na pag nakasara ay di kita.
    Di naman kita pero alam kong nandun kaya naba-bother ako hehe..
    Apr 2010
    #4866
    mga sir patulong aman about hid ano ba maganda at mura hid? can anyone enlighten me about hid para sa jazz natin? or palit bulb na lang? kasi pagpalit bulb kailangan ata palitan yung wiring nito kasi nasusunog kailangan pa ng relay parang ganun din parang nagpahid ka din. hope can you help me guys. siyaka pala i need inputs about 3000k bulb and 6000 k bulb. thank you gurus!
    #4867
    Don't switch to HID unless you're willing to do a projector retrofit (20+k)
    Sabog buga ng HID kapag hindi ka naka projectors - it produces glare for other motorists because normal reflector headlights designed for halogens aren't meant for HID. Iba yung beam pattern ng halogen sa HID kaya sabog.
    Also, as driver, you get reduced visibility because kumakalat yung beam ng HID instead of it being properly directed to the ground when a halogen bulb is installed.
    If you want, you can just buy ultra white halogen bulbs. Palit bulb lang, walang glare, wala nang kakalikutin sa electricals (because you no longer need a ballast etc). Mas mura lang din kapag bulb lang papalitan mo.
    Mar 2005
    #4868
    Mag osram night breaker ka na lang or Philipps Xtreme Power H4 bulbs. Sayang lang pera mo sa HID kung naka stock head lamps ka pa din. Mambubulag ka lang ng kasalubong mo
    #4869
    Quote Originally Posted by mda View Post
    I beg to disagree. Super white bulbs tend to produce glare too and emit less light compared to halogens. Plus, it's completely useless when it rains.
    My advice - get projectors . kahit bolt-ons lang - (
    ( may binebenta si tucson88, 6k+ lang. ) - if you really want HID.
    Apr 2010
    #4870
    * mda - kailangan pa pala ipa projector yun? kala ko kailangan lang wiring ballast and the bulb. sir ano gagawin sa hl ko kung ipapaprojector ko? wala pa kasi ako alam sa mga hid na yan kaya gusto ko malaman para hindi ako mapamahal para hindi paulit ulit isang bagsakan na lang.
    *jmpet - pap napalitan mo na ba bulb mo ano ok ba? kasi nakamanyak tint ako hirap magdrive katulad nina pumunta ako sa bulacan hindi ko mkita yung iba lubak.
    * renzo - sir renzo ipm ko si tucson ngayon tanungin ko kung magkano magagastos. sir renzo naka hid ka pap?
    *to ALL TSIKOT - mga sir pagpalit bulb lang ilan wats kaya yung safe para hindi masunog yung wiring?
    Sep 2010
    #4871
    curious lng ako about the fog lights for 1.5 GE...
    1. eto ba yung OEM fog lights na body colored from casa na P17k?
    2. meron din ba nito na aftermarket verision same din na body colored for the polished metal?
    3. pano yung installation? kelangan bang i-cut yung section ng bumper - left and right?
    thanks!
    #4872
    Quote Originally Posted by lae View Post
    dont just replace your stock bulbs with HID bulbs, kawawa mga makasasalubong mo.
    If you like to use HIDs, retrofit your headlamps with projectors so that you'll have a nice cut off line and avoid blinding oncoming traffic.
    ok din reviews ng osram night breaker bulbs
    may magaling na nag-retrofit ng hid bulbd dito sa tsikot. garyq ata pangalan niya, search mo nalang.
    #4873
    Quote Originally Posted by aLbEe View Post
    boss, talaga pong ninipis yung clearcoat mo. rubbing compound kasi medyo aggressive
    Apr 2010
    #4874
    oo nga sir nagtanong na ako kung magkano aabutin kay garyq hindi pa nagrereply pap e. napalitan mo na ba yung ilaw mo pap? ui watusi member ka ba sa hcp?
    #4875
    hindi ko pa po napalitan pero im planning to
    share ko lang....kaninang gabi, may nakasalubong akong white GE sa may New Manila, lakas ng ilaw tapos may cut off line, I wonder kung osram night breaker na ba yun? ganda at lakas ng buga tsaka hindi nakakasilaw sa nakakasalubong. member kaya ng tikot yung nakasalubong ko na yun?
    may blue GE din ako kanina nakita, naka HID pero hindi retrofitted yung HL, nakakabulag!
    hcp, nope, bakit?
    #4876
    Ballast and bulb for the "ricer" HID. Papalitan yata yung loob ng HL - not sure, ask experts like si garyq.
    Kapag papalitan mo yung bulb with a different color halogen, better kung pareho lang wattage. 55W YATA yung stock. Better check nalang sa manual if it's there.
    Apr 2010
    #4877
    * watusi - asa warranty pa yung oto mo? hid plan mo? baka member ng hcp yun what plate no. nakita mo ba sir?
    * mda - thank you sir. i already send him a message hintay ko pa reply niya e. nakita mo yung kay tucson yung add niyo ang mura ng benta niya ng projector and hid all in na ata yung 6 plus K
    #4878
    naku, hindi ko na maalala yung plate #, plano ko osram NBs lang para dilaw padin
    Apr 2010
    #4879
    sayang. bulb papalitan mo sir? sana makita ko yung iba ge na naka projector na at nakahid
    #4880
    ito palagay mo
    ito yung link sa sulit - http://www.sulit.com.ph/index.php/vi...ith+angel+eyes
Second Gen. Honda Jazz/Fit
