Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2010
    Nag-ooverheat ung honda vti '96 ko at pinagawa ko na sa mekaniko. Nagpalit na ako ng cylinder head gasket, timing belt, valve cover gasket, etc. Napareface na rin ung cylinder head at 3x daw isinalang at malaki kinain sa torno. Ang kaso, hindi pa rin nawala overheating, lumakas pa consumption ng gasoline at hindi maganda combustion ng car. Ang ginawa ng mekaniko, nag double gasket kami dahil manipis na raw ung cylinder head. Pero ganun pa rin ung temperature. Ang gusto ngaun ng mekaniko is ireplace na ung cylinder head dahil manipis na nga at kahit ano gawin hindi raw ma-totono makina unless mareplace na talaga.
    Any suggestion kung saan makakabili ng surplus na Cylinder Head ng Honda Civic Vti '96? Magkano kaya ang surplus? Magkano rin ung brand new para may comparison ako. Sana merong mabilihan ng mura lang. Malaki na rin kasi inabot sa gastos ko.
    Jan 2010
    Pangit ng internet connection, nag double post tuloy. Mga moderators, paki delete na lang po ito. Sorry.....
    baka hindi cylinder head problem yan.
    maghanap pa kayo ng ibang sanhi ng overheat.
    to state the obvious, i'd test the auxiliary fans. i'd look for leaks.. i'd have a proper engine tune-up.
    and i'd replace my mechanic.
    Jan 2010
    Newly overhauled na radiators and don't have leaks sa cooling system. Bumili na rin ako ng new auxillary fan motor pero no effect pa rin. Maganda takbo ng engine on idle pero pag medyo high rev na dun mararamdaman ung combustion na hindi maganda. New na rin radiator cap. Nung natorno kasi ung Cylinder head medyo makapal nabawas kaya need na raw ireplace.
    Any suggestion where to buy Cylinder Head? Ung mura lang.
    Aug 2005
    kamusta naman ang engine block. baka may mga scales na kaya hindi maganda ang heat conduction from the engine block to the coolant.
    kamusta naman ang water pump at thermostat?
    Jan 2010
    pwdeng may ibang problema pa yan.check your water pump,radiator,thermostat, possible worn host...theres a lot of things to consider...
    baka nga sobra ang na bawas sa head, kaya tumaas ang compression ratio ng engine mo which results to more heat. what is the symptom of overheat nayon?
    Jan 2010
    Ok naman sir ung water pump. Wala na rin nakalagay na thermostat. Nirekta na rin namin ung auxillary fan para deretso andar.
    Jan 2010
    Quote Originally Posted by ARB View Post
    Eto na nga sir ang sinasabi ng mekaniko; dahil sa sobrang kapal nabawas during pagtorno, naka 3x na isinalang kaya parang medyo tumukod na. Ung compression ratio tumaas. Hindi ramdam pag naka idle ang andar dahil maganda combustion pero pag naka rev up na hindi maganda tono ng andar.
    Uulitin ko po, wala leaks sa radiator and hoses; mga 2 months pa lang nalinis ung radiator; working po ung water pump dahil kasama sa nabaklas un nung pinalitan ng timing belt and tensioner kaya nakita ung pump; bago na rin ung auxillary fan (nakarekta pa rin fan para deretso andar temporarily).
    What I need right now is kung saan ako makakabili ng surplus na cylinder head na mura. Magkano rin kaya un?
    Aug 2005
    OT ng konti.
    nagpalit ako ng cylinder head sa 2001 Altis namin. 29K ang surplus cylinder head, pero nakabili kami sa Alabang Parts ng brand new for 39K. Share ko lang para may idea kung gaano kasakit sa bulsa.
Replace of Cylinder Head to prevent overheating
