Results 1 to 7 of 7
- May 2007
- 104
November 3rd, 2009 06:52 PM #1Tanong lang mga sir...
I've consulted a bunch of honda experts on this... just want to get your opinion... Almost all of the guys/experts/even mechanics i asked about checking ATF fluid level on an Automatic tells me "ilagay mo sa drive habang may tao sa loob ng koche na naka apak sa brake, saka mo ilubog ang dipstick para tama ang basa ng ATF fluid level"
im sure you guys have heard of this process before...
now my question is... is this really the proper way of checking ATF Fluid Level on a Honda 1995 ESI?
based from a service manual that i downloaded over the net (service manual for honda civic 1992 - 1995)... here what it says...
I just need your inputs on this one... nung nagbasa ko to sa manual, ganito na ang ginagawa ko. bakit lahat ng tao hinde ganito ang sinasabe
November 4th, 2009 05:20 AM #2
sundin mo lang ung nakalagay sa manual,,, pero mas maganda kung idrive mo muna civic mo maybe about 1-2km then stop kana dapat sa level ground tpos lagy mo na sa "P" shut off the engine then check the atf fluid level.
November 4th, 2009 07:05 AM #3
while the engine is running and in running temperature, pull out the AT dip stick.. dapat nasa full-mark yan..
NEVER CHECK KAPAG NAKA-D ANG AT...PWEDE NA SA P YAN... safety first..mahalaga, tumatakbo ang makina.
November 4th, 2009 07:45 AM #4
Just follow the service manual regarding the correct way to check ATF fliud level and the reccomended ATF fluid and make sure you dont overfill .
- Oct 2009
- 12
November 4th, 2009 02:11 PM #5Nothing experts than the one who design and make the car. If the manual say so then go for it. Don't be a fool checking your car in unsafe manner always think of safety first. This manual is design to guide you in checking your car when you are only by your ownself.
November 4th, 2009 02:43 PM #6
- May 2007
- 104
November 5th, 2009 11:38 AM #7salamat sa mga inputs sir... tama nga naman wala nang ibang may alam nyan kung hinde ang gumawa nito...
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
