Page 30 of 56 FirstFirst ... 2026272829303132333440 ... LastLast
Results 581 to 600 of 1104
    Nov 2011
    #581
    guys help me nmn on my car just bought it a month ago sa isang barkada ko Honda Accord Exi 96 Matic pag drive ako sa NLEX steady 80 to 100kph takbo ko 10mins pa lang na ganon overheat n sya halos nasa red na in just 2 mins kahit slow down ko na to 60kph tumataas pa rin ung temp nya pero pag sa city ako drive d nmn nag ooverheat yung car 1st tym ko palang magkaron ng car and almost 3 months old p lng sakin to ano po kaya sa tingin nyo PROB ng car...sana mbgyan nyo ko idea bago ipagawa to...PLZZZ Guys help me
    #582
    1. i would clean the radiator. i'll have the external cooling fins cleaned using soap and water and a hi pressure washer.. baka marumi lang.
    2. if it doesn't improve, i'll suspect blocked water passages in the radiator. this calls for radiator overhaul.
    3. i'd also check the auxiliary fans. are they rotating ok? they normally blow a lot of air thru the radiator.
    Jan 2011
    #583
    Quote Originally Posted by nubie_yahero View Post
    Fellow tsikoters and GEN 2 CRV drivers/owners,
    Kamusta sa lahat. I drive a standard shift 2wd CRV. I always try ways to have better fuel efficiency on my ride.Regular maintenance and even sa pagtanggal sa 3rd row seat kung hindi naman namin ginagamit.hehehe. Anyway,
    I read this article , Driving Tips to Save Gas - Save Gas This Summer - Popular Mechanics
    , a few months before.
    One item suggested this
    "Tactic No. 2: Avoid Slowly Crawling Up to Speed
    Conventional wisdom says that jackrabbit starts consume more fuel. But it turns out that nursing your speed up to the limit too slowly also lowers mpg. How can that be? Cars get poorer fuel economy in lower gears, and accelerating too slowly prevents upshifting at an efficient rate. The best acceleration rate varies with the vehicle, gear ratios and weight. But in our testing we found that taking 15 seconds to accelerate to 50 mph used less fuel than taking 30 seconds to reach the same speed, because the car entered its top, fuel-​saving gear sooner.
    Read more: Driving Tips to Save Gas - Save Gas This Summer - Popular Mechanics
    It made me think whether this applies also to standard shift vehicles or only to automatic transmission.
    Alalay ako mag accelerate , as needed basis lang ang sudden acceleration for me. Nalito tuloy ako
    kung mas nakakatipid ba ako sa driving habits ko o dapat ibahin ko.
    Your input are appreciated.
    Read more: http://tsikot.com/forums/honda-cars-...#ixzz1cnUnjy1u
    i believe that's correct and it makes sense. thats what im doing. have the car hataw para magshift kaagad ang A/T sa higher gear. malakas sa gas pag mabagal ang start mo. pagdating sa 60-80kph, maintain ko nalang. i think mas matipid ako sa ganito compare sa dahan -dahan. matik sa akin, dont know about manual.
    Jun 2007
    #584
    sir whats the fuel consumption ng Accord 1994? 2.0 yung engine po
    Sep 2011
    #585
    Hi, i just got a honda jazz 2012 model 1.5 A/T 2 months ago exact date is sept 16, and one of the reason na jazz kinuha ko is ma tipid daw sa gas, for my 1st month nag tataka ako bat ang lakas sa gas ng jazz ko nasa 7km/L city driving malate to ortigas full tank ko umaabot lng 5 days minsan 4 days lng normal driving normal apak sa gas , as searching for some answer me nabasa ako sa isang thread dito na gaganda daw ang FC and performance after 1kpms, but ryt now 2 months and 1 week na car ko my FC still the same nasa 7km/l parin, is there a problem with my jazz 1.5 2012 model? or ganun talaga? hope someone can help me regarding my fc, thank you
    Jul 2011
    #586
    Quote Originally Posted by SkyeEvo View Post
    someone mentioned in another thread that "fuel economy is 90% driver and 10% car". sir I suggest that you search the internet on driving techniques for fuel economy. you can start with this site 100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com.
    Aug 2011
    #587
    yehey roll back ulit!
    Jul 2011
    #588
    Quote Originally Posted by jazzinmypants View Post
    less than 50 petot ang exreme97 sa tandang sora
    Aug 2011
    #589
    full tank today with unleaded * 50.55. sana below 50 na nxt tym!
    computed my fc today.
    trip: 289.5
    dashboard fc:10.8
    manual compute: 10.597
    medyo tumaas fc ko. tsk tsk... last time was 13.3 manual compute. halos same lng nmn biyahe.
    just sharing..
    Sep 2011
    #590
    hi guys. newbie here. im planning to buy a honda city s m/t or a vios e early next year. mejo confuse kung alin sa dalawa ang bibilhin ko although 80% sure na ako na in terms of practicality and fc, mejo lamang ang vios. darkhorse ang city pero ang lakas kasi ng dating sakin ng habanero red na city. tanong ko lnag sa mga may ari ng city, mabigat ba ang piyesa nito. aside sa usual na change oil, alin ba ang unang pumapalya na piyesa ng city. your inputs will be a great help. thanks.
    May 2011
    #591
    sino naka crv gen 1 dito.. para kasing mas matipid ang crv natin pag Shell vpower gas ang gamit.
    Oct 2011
    #592
    mga sir, i own a 2004 a/t crv, and i am planning to trade iti in with 3rd gen crv, may i ask in terms on fc, which model ang mas matipid sa gas?
    #593
    Trip: Greenhills-QC-Paranaque
    80% C5
    10% EDSA
    10% Inner streets
    Conditions:
    Along C5, I hardly went down below 95kph.
    Car was loaded with passengers ( 5 pax. ) and trunk was full
    Fuel was 3/4
    Fuel consumption: 11km/L
    Car: 2010 Honda City 1.5E
    Oct 2011
    #594
    hi sir kakatapos lang sa service ng car ko honda civic 2008 esi city driving 5.3 lang kaya dinala ko na sa service center after tumaas lang ng mga 7 km per liter city driving 10 pag hi way ok lang ba itong FC ko? ang dami na kasing naglalabasan na auto ngayon na ang bababa ng FC my be its time to change for a new car maker like hyundai.. malakas ata talaga ang honda sa gas..
    Dec 2002
    #595
    Quote Originally Posted by isagani_pags View Post
    kapag vtec mode lagi malakas nga, yung tipong laging karera mode nasa isip.
    Jan 2012
    #596
    naka honda frankenstein ako na makina. Matulin at malakas ang power na tipong kayang sumibak ng Sir pero nag sisi ako kasi sobrang lakas sa gas! Hindi na paractical pang everyday use. ahahaha! from my old engine that consumes only 10-12km/lts city driving to 2.5-5kms/lts nalang. Nakakabadtrip talaga sa consumo pero ka enjoy din mag hataw! kaso ngyon commuter na ako kse mahal na ulit ang gas! Balak ko na bumili ng matipid na oto kasi pamilyado na din ako. ano ba ok na model vios or city?
    Thanks guys!
    Jan 2012
    #597
    hi everyone! Im planning to buy honda civic esi 94 model ph16 and all stock makina. Gusto co po malaman fuel consumption nia, sabi kasi mas matipid daw pag nka EFI, ung 1st car co po na toyota small body all stock 16v nkakakuha pa po aco ng fuel consumption of 10km/l combined city and hi-way na po, ang route co po eh from libis to antipolo hills subdv. naka aircon po all the way. mas matipid po kaya sa fuel consumption ang honda esi 94 model na balak co kunin? ayaw co naman po kasi bumili ng 1300cc kasi kagabi nka drive aco ng corolla 97 mdl na 1300cc ang displacement super tipid po tlaga sa gas hands down pero super bitin din po sa hatak. pakiramdam co hindi aco maka-akyat ng maayos sa antipolo knowing yung route na Dinadaanan co. feedback po from esi owners and alike will be greatly appreciated po! ty!
    #598
    Quote Originally Posted by 3GEMS View Post
    CRV Gen1 petron extra nasa 6km/L.
    2000 AT. City driving, MLA-MAkati-MLA via UN Kalayaan
    Ok na ba FC ko?
    Apr 2008
    #599
    Sirs,
    A newbie to a CIVIC FD '06 2.0S here. Just got it last Friday. My last honda was a 96 ESI model which i changed to D15B engine which is so fuel efficient.
    question, what is the average FC of this 2.0S? i am a bit conscious of the fuel guage coming from my '01 altis 1.6G AT
    Please advise sirs!
    Thanks in advance
    Feb 2012
    #600
    Quote Originally Posted by dembi View Post
    Ako usually 7.5km/l din. Nung nilinis ko yung air filter ko, nakaka 10km/l na ako. Pero malaki pinagbago ng driving style ko. Very light yung foot sa pedal na halos walang acceleration...
    what is the proper cleaning of air filter? any km to be follewed? thanks
Honda Fuel Consumption Database
