Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
    Feb 2018
    Hi all,
    I just changed my civic fd for a 2008 crv.
    It is 2.0 2x4 automatic with electronic power steering.
    I am having 2 problems.
    milage is 96k and I just changed 3 mounts which were all broken.car was vibrating like crazy.
    1)changed left mount, right mount and 1 transmission mount. Is there any more mounts? Car is still vibrating at idle... And it's idleing at 400-500rpm is this normal?
    2) when changing from N to D, there is 1 sec delay and thrb a bad jerk from transmission. I thought it is because of the mount but it stikk remains even after changing....
    its idling badly because 3 things.. ignite, compression, fuel.
    check codes kung meron scanner. if not find a honda mechanic...
    Feb 2018
    hi,
    i seeked some professional help. they said the knocking sound is from the electronic rack and pinion.
    and the jerk is from the transmission.
    15k for the rack and pinion seals and 45k for transmission rekit and repair..... does this sound good? thanks
    Quote Originally Posted by szekan View Post
    Hi all,
    Idle should be around 700-850rpm..imo
    Mar 2004
    Honda CR-V 3rd gen still uses hydraulic power steering ... not EPS ...
    hi,
    it does not sound good.
    is this casa, or non-casa?
    Aug 2017
    Aug 2017
    hi,
    I suggest you to go step by step, eliminate the simple and cheap problems first.
    Stock engine is right, have it scanned first.
    Dr D is right, how can you have a rack and Pinion problem if the CRV is not EPS?
    45k tranny rekit and repair... Very expensive to me... Try changing the ATF first, with the right ATF grade, if this can handle Dexron 3, my recommendation is Eneos D3 ATF (corrected my 2014 Ford Everest's notorious shift shock), this will cost you around P270 per Liter + P300 labor.
    As for the supports, the most I've seen is 3 supports, all of which you said you've replaced. So move forward.
    Yes the RPM is too low for any vehicle. A scan will guide you best.
    Feb 2018
    The 2.4 comes with oil while the 2.0 comes with eps... It came as a surprise to me as well....
    Feb 2018
    The 2. 4 uses hydraulic while the 2.0 uses eps...
    Feb 2018
    Quote Originally Posted by SidCoronel View Post
    1) My crv is 2. 0 and this variant comes with Eps po.
    So the latest news is I rebushed the rack and pinion and now the knocking noise on rough road is gone. First shop gave a price of 15k then second shop 13k then third 9500 and then finally one guy did it for 5k.
    2) I changed the spark plugs and checked the throttle body, it's super clean. Next I put the car on OBD scanner and there are no codes at all. Yet the car idles at 400-500rpm. Car doesn't stop or anything, just some annoying vibrations on idle....
    3) I found a shop in banawe who is willing to repair my auto tranny for 30k... Not sure if this is a good deal?
    I was thinking to try to flush the ATF but all the mechanics saying that this sort of jerk is related to clutch problem not Atf....
    Mar 2004
    Did you have throttle body and idle control valve cleaned before? ... Did the mechanic perform idle relearning? ... Check online on how to perform idle relearning ...
    Feb 2018
    HI, yes I have done all of it. Still just remains 400-500.
    There is no surge or jumping rpm or car switching off. Just low rpm that's all
    Saang area ka? My trusted mechanic is in bacoor. Former assistant of mel casaba.
    Mar 2004
    Perform proper idle relearning ...
    Feb 2018
    hi guys, 1 week is gone and i am still repairing my car. at the start of this thread, my car had 3 problems...
    1) knocking noise from under the car
    2) transmission jerk and delay shifting
    3) low idle rpm
    so far work conducted
    1) changed the following parts
    LH engine mount
    RH engine mount
    Rear transmission mount
    2 x KYB front shocker
    1 x strut mount bearing
    2 x stabilizer link
    plus labor
    31,000 peso
    rebushing of rack and pinion
    rack end and tie rod repair
    ball joint press
    labor
    6,500 peso
    All knocking noise solved.
    2) changed the following
    Surplus transmission and changed the damaged gears
    8 litre transmission ATF
    labor plus home service
    30,000 peso
    Transmission solved
    3) did the following
    new spark plugs
    cleaned throttle body
    cleaned MAF sensor
    reset ECU
    Reset throttle position
    still the car idle is very low.... it is now in the hands of a very qualified technician by the name of Frank De Leon. hopefully he will solve this in his own fashion.... shall update soon
    3) low idle rpm
    LH engine mount
    RH engine mount
    2 x stabilizer link
    plus labor
    31,000 peso
    ball joint press
    labor
    6,500 peso
    30,000 peso
    Transmission solved
    new spark plugs
    cleaned MAF sensor
    reset ECU
    How bout yung IAC valve? Nalinisan na din?
    Baka need na mag replace ng component at hindi na kayang linisin? Have you tried adjusting the rpm at idle? May kinakalikot yan, i forgot where kasi sa mazda gen2 ko pa nagagawa yun dati...
    Feb 2018
    Yes not yhe Iac value... Maybe that's the problem I am not sure... This crv doesn't have any physical adjustment to control idle...
    Hopefully by tonight I shall know what is the real problem.... Technician also said that these problems which I am facing are very common for crv....
    You need an OBD dedicated to Honda to reset the idle speed to 650 rpm factory default.
    Problem ko before is high idle speed at 1000 rpm after cleaning my throttle body.
    Mine is 2009 crv 2.0 litter.
    Feb 2018
    Quote Originally Posted by joepaps View Post
    Not sure about the dedicated OBD. But they used theirs and tried to reset many things but nothing happened. There is no stored error codes or engine check.
Honda crv 3rd gen issues please help
