Wow thats bad.
Posted via Tsikot Mobile App
Air intake lower than the headlights, per India forum, kaya kahit mababaw baha para siyang may straw na hihigupin yung mababaw na tubig.
Pero i-dtec lang naman di ba? Kung ni-transplant lang nila yung 1.3l ng city dati, mataas ang intake nun. Sa may radiator grill ata CMIIW.
according sa forum, i-DTEC (Diesel) model lang ang nagkaroon ng issue. not affected ang i-VTEC (Gas) models sold locally.
Just got a chance to check my petrol Amaze physically. Unlike diesel air intake, in petrol variant is on top as Tiger_Stripes rightly said at the level of headlight. Big relief.
Breaking Free: Driving the 2014 Honda Brio and Brio Amaze in Bicol | ************ - Philippine Car News, Car Reviews, Auto Features, and Car Prices
pathetic FC:
During this close to 200-kilometer drive, both cars managed figures northward of 11.3 km/L
I wonder what the FC would be if driven with ECO On all the way.During this close to 200-kilometer drive, both cars managed figures northward of 11.3 km/L; pretty commendable given the ECO coaching light rarely lit.
The ECO Light will come on when the engine is running efficiently, whether the engine is running on less cylinders, or you are driving at a steady RPM, etc.
Guys, is brio really that bad a deal? Im considering this for my first car actually because of the 1.3l 4cy engine that's supposedly more balanced against its 3cy counterparts. Parang wala kasi msyado ngpopost for this model unlike the other brands..
"plumbing for the air intake is on the underside of the bonnet.."
i couldn't find a picture that explains it all, but this statement above , to me, means that water can get sucked into the cylinders just by throwing a pail of water onto its nose..
it also suggests, if the owner simply removes this intake, the problem is solved. it's ugly, but it's solved.
my old cedia also had its air intake up front, but it's protected from direct splashing by sheet metal..
apparently, the brio's is not protected at all from direct splashing.
Sa mga Amaze A/T owners ano average FC nyo?
Honda Amaze S A/T unit ko, average FC ko light traffic (6am wekdays Via EDSA) ay nasa 10-11km/L pero kapag medium to heavy traffic (5pm via EDSA) ay nasa 8-9km/L.
kanina 6am via EDSA pumalo ako ng 13km/L (ngayon ko lang sinubukan > naka neutral kapag pababa ng flyover at minsan kahit patag basta nag-gain ako na ng momentum then alaly na lang sa brake) pero baka tsamba lang ito hehehe.
25km ang byahe ko valenzuela to makati via EDSA
slipping it in N while moving is quite dangerous
di yan katulad ng old cars na carburator type fuel system it would gain you nothing
Thanks For the information, i did a little research and from what I've read you will not save gas putting most automatic transmission cars in neutral, since most cars use fuel injection and are set to dispense the same amount of fuel at idle regardless of being in Neutral. Also, switching in & out of gear while moving might stress the mechanicals... Not a good idea. kaya mga sirs wag tutularan![]()
Neutral coasting works. Sometimes, preserving momentum is more important than getting exactly 0 liters of consumption per kilometer... because you'll need to spend more fuel getting that speed back.
How stressful it is for the car depends. On most modern automatics, it should not be a big problem. It should be noted that there are automatic transmission cars nowadays that shift themselves into neutral when you lift off the pedal... to save gas. ;)
not sure if wala lang masyado feedback on the Brio since it's new. but reviews in TPG and autoindustriya seem generally positive right? planning to test drive one this weekend.
My sister just got a Brio V a/t last week. mas power full kaysa sa Mirage gls CVT. Pero mukang mas matipid ang Mirage and mas maluwag.
Dahil hindi CVT ang Brio, ramdam ko ang mga up-shift nya.
Try ko sa SLEX tomorrow. Santa Rosa to Calamba and back in the evening.
