Page 1 of 2 12 LastLast
Results 1 to 20 of 55
    Apr 2008
    P to D and R shutters, anyone experiencing this on early civics, accords and city??
    Changing your tranny is not the only option ^_^. Its repairable.
    I have a shop in imus cavite... give me a pm maybe i can help you guys out.
    Aug 2013
    Quote Originally Posted by bong06 View Post
    Mine does. Problem is I'm mostly in Quezon CIty.
    Sep 2013
    Our car does not shudder, but after shifting from P to R it reverses then pauses before reversing again (normally we don't step on the gas when reversing from parking). It seldom happens when we shift from P to N before shifting to R. Are you familiar with this problem? Estimate cost?
    Thanks
    Mar 2012
    Quote Originally Posted by jeremy.cruz View Post
    Thanks
    90% flywheel na yan, had the same symptoms 3 years ago.. had the flywheel replaced sa honda makati inabot nang about 18k... pero malamang mas mura sa labas try banawe... pm mo si sir wezz wew and check out the first gen honda gd thread..
    Apr 2008
    Thanks
    You may have defective seals at your 3rd gear planetary, if its still the original transmission baka medyo matigas na yung seal, therefore preventing the correct pressure na mag build up para matulak yung clutch pack. here is an example nung assembly.
    Mar 2013
    Timely thread as I am experiencing transmission problem on my x-trail.
    May mga instances na hindi umiilaw ang O/D when I turned it off, at pag nag yari yan eh mahina na sa arangkada ang sasakyan. The problem is intermittent at the moment.
    Yun nga lang dito ako sa Pangasinan.
    Apr 2008
    have u tried scanning your ecu?? maybe youll come up with some trouble codes
    Jun 2004
    How much rough estimate to rebuild/replace the internal seals? Ang problem nung sakin pag malamig pa engine kelangan mag wait ng 5 minutes bago sya umatras tapos pag first gear medyo mataas rev nya bago magpalit to 2nd/3rd gear. Pag mainit na engine normal naman lahat.
    Apr 2008
    Quote Originally Posted by chris_d View Post
    Good Morning,
    Can i ask what type of car??, civic? CRV? city?? year and model??
    Thanks
    Sep 2013
    Thanks
    We tried cvt flushing as suggested by a mechanic and the problem appears to have been fixed. The car no longer pauses when we shift from P to R directly. We were told that the flywheel replacement is for the shudder problem which was not the problem we were encountering. Thanks all.
    Oct 2015
    can you pm me your details?please thanks
    Aug 2010
    Sir pa PM ng contact details nyo. Thanks.
    Sep 2013
    Im having problems with my transmission as well mine is a 2006 1.3 dsi. nag jerk siya sa low gears but intermittent. Honda Q Ave checked it before and they just reset the system adn cleaned the shift solenoid pero ganun pa rin. Any advice on how to go about this. Pa email naman po at tabs1073*yahoo.com
    If the problem is found on the Honda City and Jazz with the CVT transmission, the fault it usually the flywheel.
    It is a design fault and replacing the flywheel will just fix the problem until a few years later it will occur again.
    I have a jazz 07 cvt. I learned from the other thread that turning off the aircon when reversing helps alot. Indeed it prevented from worsening the flywheel issue
    Same rin sir sakin manginig pero intermittent sya fron N to D. It might be related to idling which is a common issue for honda. Casa maintained jazz ko and 100k na and still experiencing problems. Biggest issue ko actually is battery which runs out every 18-20 months, lugi ang motorola sakin
    Nov 2014
    Quote Originally Posted by neillien View Post
    Soir ano sabi ng Casa about dun sa nanginginig from N to D??? Di mo na solve?? Hinayaan mo lang sir??? Gano na katagal ganun??.
    Jun 2015
    Hi good am. Newbie lang po. Check ko lang po kung ano kaya problem ng honda civic lxi automatic 99 ko. Matagal magshift sa 3rd gear at hirap sa uphill roads and overtake. Thank you. Cavite area po ako.
    Aug 2014
    Things i did since January:
    • Replace CVTF at Honda Otis, calibrated - observe.
    • Replace top valve cover gasket at Honda Otis - observe.
    • Change Oil (Motul fully-synthetic)
    • Change all Eight spark plugs, Air filter, Front disk brakes.
    Problems:
    • Vibrates paminsan especially pag heavy gapang traffic.
    • Normal gamitin if city driving if ang takbo is 60kph to 80kph driver only or with one passenger. pero if loaded like apat na passengers medyo nadedelay yung pag shift.
    • If expressway: till 80kph lang if dahan-dahan ang pagbuilt ng speed/momentum pero pag binigla mo ayaw nya, parang manual na humihingi ng shift pero ayaw mag gear-up. pero if unti-unti ang takbo eh nakaka takbo naman ng 100-120 kph.
    Sa observations ko, para sya talagang nagdedelay sa pag dagdag ng kambyo. parang Manual tranny na 80kph na takbo mo pero naka segunda ka pa din.
    Ano problema nito? sadly sa mga napagtatanungan ko eh out of stock ang flywheel. gusto ko na nga sana palitan as sugal move baka machambahan. - Since ang change tranny option is 15k surplus plus labor medyo mahal kaya gusto ko muna maka siguro na CVT tranny or Flywheel nga ang sira bago ko ipatira para hindi masayang pera.
    Please advice. email me doddie.gutierrez*gmail.com or SMS 0927 7555481 if seller kayo ng iDSI Flywheel at tranny for Honda City iDSI 2005.
    Thank You!
    Quote Originally Posted by page7fordoddie View Post
    Problems:
    Thank You!
    Hi Sir Doddie, very informative post. we have the same car model. Ask naman ako contacts ng shops outside casa para makamura. Malapit lang ako nakatira sa Honda Otis.
    Issue ko is ung sudden 5 secs freeze from N to D. Plus ung hinde nagststart either sa P or sa N.
    thanks sir!
    Problems:
    Thank You!
    thanks sir!
Honda Automatic transmission problems P to D and R shutters
