Results 1 to 10 of 55
- Apr 2008
- 112
July 25th, 2013 11:44 AM #1P to D and R shutters, anyone experiencing this on early civics, accords and city??
Changing your tranny is not the only option ^_^. Its repairable.
I have a shop in imus cavite... give me a pm maybe i can help you guys out.
- Aug 2013
- 2
August 22nd, 2013 10:24 AM #2
- Sep 2013
- 4
September 22nd, 2013 07:02 PM #3Our car does not shudder, but after shifting from P to R it reverses then pauses before reversing again (normally we don't step on the gas when reversing from parking). It seldom happens when we shift from P to N before shifting to R. Are you familiar with this problem? Estimate cost?
Thanks
- Aug 2010
- 86
- Mar 2012
- 351
September 23rd, 2013 09:39 PM #5
- Sep 2013
- 2
September 23rd, 2013 11:32 PM #6Im having problems with my transmission as well mine is a 2006 1.3 dsi. nag jerk siya sa low gears but intermittent. Honda Q Ave checked it before and they just reset the system adn cleaned the shift solenoid pero ganun pa rin. Any advice on how to go about this. Pa email naman po at tabs1073*yahoo.com
September 24th, 2013 09:38 AM #7
If the problem is found on the Honda City and Jazz with the CVT transmission, the fault it usually the flywheel.
It is a design fault and replacing the flywheel will just fix the problem until a few years later it will occur again.
- Apr 2008
- 112
September 30th, 2013 10:48 PM #8
September 30th, 2013 11:34 PM #9
Timely thread as I am experiencing transmission problem on my x-trail.
May mga instances na hindi umiilaw ang O/D when I turned it off, at pag nag yari yan eh mahina na sa arangkada ang sasakyan. The problem is intermittent at the moment.
Yun nga lang dito ako sa Pangasinan.
- Apr 2008
- 112
October 2nd, 2013 12:20 AM #10have u tried scanning your ecu?? maybe youll come up with some trouble codes
high idle RPM at engine start
