Results 21 to 30 of 55
- Jun 2015
- 3
June 12th, 2015 10:07 AM #21Hi good am. Newbie lang po. Check ko lang po kung ano kaya problem ng honda civic lxi automatic 99 ko. Matagal magshift sa 3rd gear at hirap sa uphill roads and overtake. Thank you. Cavite area po ako.
June 15th, 2015 10:19 AM #22
Things i did since January:
• Replace CVTF at Honda Otis, calibrated - observe.
• Replace top valve cover gasket at Honda Otis - observe.
• Change Oil (Motul fully-synthetic)
• Change all Eight spark plugs, Air filter, Front disk brakes.
Problems:
• Vibrates paminsan especially pag heavy gapang traffic.
• Normal gamitin if city driving if ang takbo is 60kph to 80kph driver only or with one passenger. pero if loaded like apat na passengers medyo nadedelay yung pag shift.
• If expressway: till 80kph lang if dahan-dahan ang pagbuilt ng speed/momentum pero pag binigla mo ayaw nya, parang manual na humihingi ng shift pero ayaw mag gear-up. pero if unti-unti ang takbo eh nakaka takbo naman ng 100-120 kph.
Sa observations ko, para sya talagang nagdedelay sa pag dagdag ng kambyo. parang Manual tranny na 80kph na takbo mo pero naka segunda ka pa din.
Ano problema nito? sadly sa mga napagtatanungan ko eh out of stock ang flywheel. gusto ko na nga sana palitan as sugal move baka machambahan. - Since ang change tranny option is 15k surplus plus labor medyo mahal kaya gusto ko muna maka siguro na CVT tranny or Flywheel nga ang sira bago ko ipatira para hindi masayang pera.
Please advice. email me doddie.gutierrez*gmail.com or SMS 0927 7555481 if seller kayo ng iDSI Flywheel at tranny for Honda City iDSI 2005.
Thank You!
June 15th, 2015 10:30 AM #24
June 15th, 2015 11:06 AM #25
You can't really check engine mount by just looking at them. The rubber compound looses it's efficiency after a decade or so.
June 15th, 2015 11:35 AM #26
- Dec 2006
- 61
June 16th, 2015 02:28 PM #27Hi Sir Doddie, very informative post. we have the same car model. Ask naman ako contacts ng shops outside casa para makamura. Malapit lang ako nakatira sa Honda Otis.
Issue ko is ung sudden 5 secs freeze from N to D. Plus ung hinde nagststart either sa P or sa N.
thanks sir!
thanks sir!
June 16th, 2015 04:14 PM #28
Posted the same question on Facebook under JazzCity United Group.
Here's the link check this baka makatulong. ---> https://www.facebook.com/groups/jazz...=group_comment
Also if magka solution na yung problem mo (which is lahat sila flywheel ang tinuturo) please share din here. thanks
- Jul 2012
- 345
June 16th, 2015 08:47 PM #29share k lang..
Had the same issue with my jazz gd3.. nung una nag slip yung tranny, nag jerk then hindi nag tagal nag bblink na yung "D". once ngyari na sa inyo to cvt tranny issue na tlga. i know replacing the cvt tranny is a drastic step.. pero after researching and asking other jazz owners na may ganitong issue it seems na replace tranny na tlga. got my tranny replaced last Jan by Mel, so far wala ako problema whatsoever.
Another issue came into play.. nag jjerk kpg idle or mabagal.. usually kpg nsa toll or traffik.. lalo na kapag bukas aircon. replaced my ignition coils.. pinalitan ko na rin spark plugs.. ayun ok na ulit. kinakapos pala ng kuryente kaya nag misfire.
sana makatulong.
June 18th, 2015 11:10 AM #30
thank you Boss for sharing, Baliktad naman sa'kin I initially checked the ignition plugs and spark plugs kaya na eliminate ko na yung jerking by misfire.
Mel? as in yung sikat na Mel Casaba dito sa forum na tiga Bacoor?
Share mo naman sakin magkano inabot change CVT mo at gaano katagal? Saka change CVT na agad? hindi mo na tnry change flywheel muna? yun kasi ang pinag iisipan ko ngayon eh.
Please answer my questions ASAP. pasensya na a abala.
You can add , The Ten Commandments, BenHur ....
Traffic!
