Results 1 to 8 of 8
- Oct 2011
- 22
October 22nd, 2011 11:03 PM #1hi sirs, my ride is 2004 crv a/t 80,ooo kms mileage. i notice my fc gone down from 6km/l to around 5.2km/l after have my car changed oil ( from fully synthetic to regular oil), fuel filter, fan belt, a/t fluid, air cleaner replaced and spark plug (iridium) cleaned, . All parts are oem and service by trusted mechanics. Ano kaya naging problema dito? thanks for your reply..
- Jun 2011
- 48
October 25th, 2011 12:27 PM #2Please try to check the SAE grade of the oil you used. Generally, SAE 50 is thicker or more viscous than SAE 40, and SAE 40 is more viscous than SAE 30 at operating temperature which is about 98 deg centigrade. It would take more power to move the engine parts with an SAE 50 oil than with an SAE 40 or SAE 30, and therefore lower fuel economy. Just my opinion.
- Jul 2010
- 165
October 26th, 2011 11:18 AM #4
- Oct 2011
- 22
October 26th, 2011 11:12 PM #5THank you mga experts, really appreciate you thoughts.. ill try to go back to full synthetic oil and lets see what happens.
October 27th, 2011 03:01 AM #6
One more thought... overtightened drive belts. If your mechanic (over) adjusted the tension of the drive belts to the alternator and AC compressor, it could also result in increased FC.
- Oct 2011
- 22
October 29th, 2011 01:24 PM #7
October 29th, 2011 02:44 PM #8
1. Yeah, check engine oil viscosity (before and after) and level
2. Drive belt tightness shouldn't be an issue since Honda's use auto-tensioners (not 100% sure for this model, though)
In most cases, this is likely caused by variances in driving patterns and/or the ECU is still trying to keep up with the abrupt change. There's probably nothing to worry about.
Ford removed the kick sensor for the liftgate? Sayang naman and I found this to be very useful...
2023 Ford Everest Owners Thread
