mga ser 2long po...ano kaya cause ng backfire? pag nabirit po kc ako sa SiR nagbbackfire pag nagslowdown...bakit po kaya? is it normal for muffler??
Type your message normally. Avoid text speak.
Have a proper tune up. Check and adjust properly the ignition timing. Maybe replace spark plug. Set air fuel mixture properly.
Use higher octane gasoline.
cguro baka kelangan ng ipa-tune up yan kelangan lang i adjust sa tamang timing ang ignition nyan
saka ipa check mo ang intake at exhaust manifold gasket mo baka may sira na kasi kapag may sira na ang mga yan nag baback fire din
sorry po di ko alam na bawal pala text format..
anyways..nakapag pa tune up na po ako..siguro pacheck ko na nga lang po exhaust pipings or ung manifold...thanks po...
If you have an open exhaust, that's normal. If it's a stock exhaust, then you're probably running too rich.
ser paano po na open exhaust?
custom headers pipings and muff na po...normal lang po yun?
Yup. That's it. If you have no more catalytic converter and your muffler is straight-through, backfiring can occur because the SiR's fuel programming is a bit rich. That's probably normal. Even so, check for unusual noises at the engine, check your sparkplugs (they should be reddish or blackish... not white or wet) and have someone check your timing.
Set your fix or base timing you would have to short the 2-PIN SCC (service check connector) located at passenger side right kick panel. It will assure that your ECU timing is starting from base calculation. Spark advance will adjust properly if ECU base timing is set correctly. for further assistance, jemsonabrigo*yahoo.com or jemsonabrigo*gmail.com Regards![]()
ser niky ano po ung catalytic converter? and mataas po ba dapat octane rating sa SiR? and mejo maingay nga po engine..pero bago na po spark plug and ok na naman daw po ang timing...tolerable pa nmn ung pag back fire kasi paminsan minsan lng nman..kaso nkakahiya pa din kasi pag birit mu sabay magbaback fire db? hehehehe..
Is it noisy at the engine end or the muffler end? If it's the muffler end, that's just your exhaust. If it's nosiy at the engine end, there are a whole lot of things it could be... exhaust manifold leak, improper timing, etcetera... best to have a mechanic check it out, as it's difficult to diagnose it online.
Freeflow muffler = backfire, malakas sa gas by 15%, bawas low end power.
Baka may singaw ang exhaust pipe at lean ang a/f mixture. Manotice mo yan kung lean ang mixture, mas malakas ang hangin na lumalabas sa exhaust pipe kaysa kung rich a/f mixture mo.
thank you ser niky....
ser pano malalaman pag may butas ang exhaust pipe? d ko po lam kung free flow ung muff ko eh...RSR po...jasma po ata...ano po ba yung free flow?
If you can look through the muffler and see the exhaust pipe on the other side, that's straight through.
Most performance mufflers have a straight pipe inside, surrounded by sound insulation. Stock mufflers, on the other hand, look like rat mazes, with walls (baffles) that redirect the exhaust and reflect the sound around inside the body (can).
