Results 1 to 4 of 4
- Jun 2010
- 5
June 25th, 2010 08:28 PM #1i just bought a 2nd hand car, 98 honda civic lxi a/t. 1month n s akin ung car so far okay nman. i decided n ipalinis ung radiator at palitan lhat ng belts for precautionary measures. nung nilinis ung radiator nalaman ko n ung water supply ppunta sa tansmission ay BLOCKED, as in sinara tlga siya. Mgtatanong lng sana ako mga gurus kung ano ang possible action n pwde ko gawin to prevent future sakit ng ulo. at ano din ung mga possible n dahilan bkit BLOCKED ung supply line ng tubig ppunta sa transmission. TNX A LOT
June 25th, 2010 08:41 PM #2
the water line to the transmission cools the transmission fluid! if the fluid overheats, it will vaporise and the tranny will be totally and utterly destroyed.
if i were you, bibili na lang ako ng surplus two row radiator (for automatics). palitan mo yung binarado na rad mo 14K din ang surlpus na transmission para sa kotse mo.
- Jun 2010
- 5
June 25th, 2010 11:54 PM #3tnx sir volts, btw as ko lng din what could be the reason bakit PUNDIDO o BLOCKED ung water supply nia ppunta sa transmission, tnx again
- Dec 2006
- 234
June 26th, 2010 08:51 PM #4
i had my original spare mag stolen, years ago. i had since installed a cheap bicycle lock, and no...
