Results 1 to 4 of 4
    Jun 2010
    i just bought a 2nd hand car, 98 honda civic lxi a/t. 1month n s akin ung car so far okay nman. i decided n ipalinis ung radiator at palitan lhat ng belts for precautionary measures. nung nilinis ung radiator nalaman ko n ung water supply ppunta sa tansmission ay BLOCKED, as in sinara tlga siya. Mgtatanong lng sana ako mga gurus kung ano ang possible action n pwde ko gawin to prevent future sakit ng ulo. at ano din ung mga possible n dahilan bkit BLOCKED ung supply line ng tubig ppunta sa transmission. TNX A LOT
    Apr 2004
    the water line to the transmission cools the transmission fluid! if the fluid overheats, it will vaporise and the tranny will be totally and utterly destroyed.
    if i were you, bibili na lang ako ng surplus two row radiator (for automatics). palitan mo yung binarado na rad mo 14K din ang surlpus na transmission para sa kotse mo.
    Jun 2010
    tnx sir volts, btw as ko lng din what could be the reason bakit PUNDIDO o BLOCKED ung water supply nia ppunta sa transmission, tnx again
    Quote Originally Posted by quezmarq View Post
    AFAIK it's the ATF that circulates into the cooler and not water?
    What did the previous owner say about the blocked atf cooler lines?
help mga sir for my 98 honda lxi a/t
