Results 11 to 18 of 18
- 54,205
March 26th, 2013 12:14 AM #11early days of e10... car not used for several months...
finally, tried to get it started.. no go..
namuo ang gasolina! naging nata de coco????
don't know if they had modified the formulation since, but we won't chance it...Last edited by dr. d; March 26th, 2013 at 12:33 AM.
March 26th, 2013 12:22 AM #12
wow! in that case im in deep sh*t! halos 1 year hindi nagamit yung ride ko....as far as i remember lampas half tank pa naiwan ko fuel. sana nag evaporate na lang yung gasolina haha!! kung bakit naman kasi may nagmarunong na naman regarding sa ethanol na yan
so petron blaze is the only 100% pure gasoline now in pinas? pwede kaya ako magpabagahe ng gasolina?? :rofl:Last edited by bobzy; March 26th, 2013 at 12:26 AM.
- Oct 2009
- 2,271
March 26th, 2013 02:56 PM #13
March 26th, 2013 03:29 PM #15
You can thank the infinite knowledge wisdom of our esteemed Senators and Congressmen for this one.
And one more thing. E10 gasoline gives you LESS kilometers per liter of fuel. So you end up paying more for the same distance. And in the same way, you pay more taxes to the government too.
March 26th, 2013 03:35 PM #16
^ So that might be the hidden agenda about ethanol. More revenue, more money in the pocket. Then again Juan dela Cruz will be the to suffer. :mad:
Sent from my GT-I9100 using Tapatalk 2
March 26th, 2013 03:39 PM #17
Well, that though has crossed my mind more than a few times when they first proposed the implementation of E10 gasoline under the guise of "clean and green" fuels. The problem was that the "green" movement was so heavy then that it drowns out the voice of "nay-sayers" to the point of demonizing them.
So we are left with "I told you so".
March 26th, 2013 03:45 PM #18
It would be best to remove the stale fuel and pump in fresh fuel. Mixing fresh fuel to stale fuel will just end up with a mix that is probably good enough to let the engine run on but it wouldn't be at best efficiency. And in my opinion, a mixed tank would be best used up asap before the mixture starts to become stale.
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
