Results 1 to 18 of 18
    Jun 2012
    Question Guys! Does gasoline expire or will go bad after a long period of time na hindi gaano nagagamit ang kotse? Lumipat na kami kc ng condo na near sa office ni wifey and work*home naman ako. Both homebody lang kami ni misis at madalang gamitin ang kotse. As in madalang gamitin kc katabi na po namin ang mall at grocery. Religously ko naman wina-warmup ang kotse every other day and naitatakbo ko naman sa parking lot ng condo para ma stretch siya at d ma diskarga ang battery and d masira ang a/c. Ang tanong ko lang paano naman ang gasoline inside sa gas tank? will it go bad ba kung d ako gaano nakakapag refuel ng new gasoline? last ako nagpa gas is mga 1st week of Feb pa. as of today more than 1/4 pa ang gas ko. Ano po ba ang tamang dapat gawin? kailangan ko ba palagi mag refuel ng new gasoline kahit madami pa gas ko at naka tengga lang kotse ko or ok lang antayin ko nlang maubos muna gas then refuel ulit or pwede din kaya kapag magpapa gas ako yung pang "1/4 refill" lang para mabilis maubos ang gas then refill ng new gas ulit ? worried lang ako baka magka effect sa performance ng kotse ko kapag old na gasoline ko. Thanks.
    Jul 2011
    Sir sa kabilang thread ung ethanol daw ang napapanis at nag attract ng moisture.
    Suggest ko na lang sayo sir invest ka na lang sa Petron Blaze, para kahit medyo matagal mo magamit ung car mo less ung risk sa panis na gasoline.
    Jun 2012
    ic, petron XCS ang gamit ko. salamt po.
    Quote Originally Posted by mido_ban View Post
    XCS contains ethanol. It will spoil if unused for a certain period. GH's got spoiled in 6 weeks. So better use it all up before then.
    E10 gasoline can "spoil" in your car's tank. With my car, it takes about six weeks before I notice a change in the car's performance (slower, less performance, harder to accelerate). By the 8th week, my car would barely start or accelerate. I have to empty my tank and pump in fresh gasoline.
    Aside from the slower performance, you'll also notice the smell of the exhaust pipe to be different from the norm, more stronger smell.
    Jun 2012
    Thanks you Sir, nagworry tuloy ako sa sinabi nyo, more thans 6 weeks na sa akin eh. hehe. ok lang po ba yung 1/4 old gasoline natitira sa tank ko haluan ko nalang ng new fuel or do i still need talaga e empty yung fuel?
    Jun 2012
    pwede siguro mag-add ng octane enhancer and water eliminator additive in case mapanis yung gasoline instead of emtying the tank. yun lang nga p500+ yata isang plastic bottle ng additive so parang nag fill up ka na din ng 10 liters ng gasoline pag bumili ka nun.
    Jun 2012
    Ok lang po ba yung 1/4 old gasoline natitira sa tank ko haluan ko nalang ng new fuel or do i still need talaga e empty yung fuel muna bago mag re-fuel?
    gamitin mo na lang para di mo na problemahin. long weekend naman e go out of town. then fill up with blaze or equivalent fuel.
    early days of e10... car not used for several months...
    finally, tried to get it started.. no go..
    namuo ang gasolina! naging nata de coco????
    don't know if they had modified the formulation since, but we won't chance it...
    wow! in that case im in deep sh*t! halos 1 year hindi nagamit yung ride ko....as far as i remember lampas half tank pa naiwan ko fuel. sana nag evaporate na lang yung gasolina haha!! kung bakit naman kasi may nagmarunong na naman regarding sa ethanol na yan
    so petron blaze is the only 100% pure gasoline now in pinas? pwede kaya ako magpabagahe ng gasolina?? :rofl:
    Quote Originally Posted by bobzy View Post
    Baka pag uwi mo, naging suka na iyan.
    You can thank the infinite knowledge wisdom of our esteemed Senators and Congressmen for this one.
    And one more thing. E10 gasoline gives you LESS kilometers per liter of fuel. So you end up paying more for the same distance. And in the same way, you pay more taxes to the government too.
    Oct 2009
    second d motion ..
    o di kaya i ref para walang panis
    joke!!!
    It would be best to remove the stale fuel and pump in fresh fuel. Mixing fresh fuel to stale fuel will just end up with a mix that is probably good enough to let the engine run on but it wouldn't be at best efficiency. And in my opinion, a mixed tank would be best used up asap before the mixture starts to become stale.
    ^ So that might be the hidden agenda about ethanol. More revenue, more money in the pocket. Then again Juan dela Cruz will be the to suffer. :mad:
    Sent from my GT-I9100 using Tapatalk 2
    Well, that though has crossed my mind more than a few times when they first proposed the implementation of E10 gasoline under the guise of "clean and green" fuels. The problem was that the "green" movement was so heavy then that it drowns out the voice of "nay-sayers" to the point of demonizing them.
    So we are left with "I told you so".
Does Gasoline expire or will go bad?
