Results 1 to 6 of 6
- Jan 2011
- 22
July 13th, 2011 01:10 PM #1mga sirs, help nmn sa problem ng honda civic vti 96 ko,
punta ko sa talyer kahapon to replace the o-ring on the distributor cup assem. kc may leak. ayun ok na ala na leak kaso nasira ata temp sensor ko kasi malapit din lang dun un.
my temp guage now is always on the highest at ung check engine light turns n after a few minutes of driving also.
tama po ba ang idea ko na connect po sa high temp sa guage ang pag-activate ng check engine light ko, patulong nmn po mga sirs . tnx
- Jun 2010
- 321
July 13th, 2011 02:04 PM #2Honda 1983-95 OBD1 Codes click mo yan para ma check kung ano problem bat nag CEL car mo
July 14th, 2011 05:40 PM #3
kahit kakasatart pa lang high temp na boss?
to check ecu fault codes, open the kick panel sa passenger side then you will see a connector na kulay green (its near the fire wall). tangalin yung cover then, may makikita na 2 pin. gawa ng palara to connect the two. there you will see the fault code
- Jan 2011
- 22
July 15th, 2011 11:18 AM #4mga paps, figured out what went wrong in high temp case only, grounded pala ung wire ng temp guage, had it fixed.
pero prob ko padin po check engine light ko which turns on, after a few minutes of driving. it turns out na wala palang bulb un dati nung binili ko from the first owner, tinangal po cguro nila para mabenta lang nila. pero ive been driving my car for 7000 kms or about 5months now, ala naman po problemang malala ang kotse so far.
[archie]Re: check engine on
sir archie anung device po kelangan ko for this? tnx
July 18th, 2011 11:42 AM #5
isang maliit na wire lang to jump the two sockets. tignan yung may brown and black wire na 2 socket, meron kasi katabi na 3 socket, wag na galawin yun.
- Jan 2011
- 31
July 28th, 2011 07:33 PM #6kailangan mo lang ng wire. tapos short mo ung plug na makaka read ng ECU check engine codes. pag may check engine ung car, hindi dapat ignore un.
Toyota Aus (and New Zealand) just resumed deliveries of the Yaris Cross. ...
2023 Toyota Yaris Cross
