mga paps, figured out what went wrong in high temp case only, grounded pala ung wire ng temp guage, had it fixed.
pero prob ko padin po check engine light ko which turns on, after a few minutes of driving. it turns out na wala palang bulb un dati nung binili ko from the first owner, tinangal po cguro nila para mabenta lang nila. pero ive been driving my car for 7000 kms or about 5months now, ala naman po problemang malala ang kotse so far.
[archie] Re: check engine on
kahit kakasatart pa lang high temp na boss?
to check ecu fault codes, open the kick panel sa passenger side then you will see a connector na kulay green (its near the fire wall). tangalin yung cover then, may makikita na 2 pin. gawa ng palara to connect the two. there you will see the fault code
sir archie anung device po kelangan ko for this? tnx
