Page 182 of 217 FirstFirst ... 82132172178179180181182183184185186192 ... LastLast
Results 3,621 to 3,640 of 4331
    Aug 2015
    #3621
    Quote Originally Posted by TheUninvited View Post
    Also, nawala yung EPS issue/sound kapag full turn.
    Not sure if dahil tag ulan? Nabasa ganun? But sealed component ata ang EPS gearbox.
    I wish bumalik para ma-warranty. Haha
    LOL! Umaaraw na, bro. You'll be able to test again over the weekend. Until when is your warranty?
    Nov 2011
    #3622
    Quote Originally Posted by xiss View Post
    Well maulan pa here today till now. 11am.
    2023 pa naman warranty ko. I got the extended for a total of 5 yrs.
    Jun 2016
    #3623
    Quote Originally Posted by stick_man08 View Post
    *xiss - oo nga pala yung extra buttons sa infotainment system.
    *Jut - Sir, ang ganda ng set up ng interior ng civic mo. I cannot send you a PM kaya dito ko nalang itanong. Care to share yung part number ng leather shift knob? Or yung taong nakausap mo sa Honda QAve para ako maginquire personally sa item? Salamat.
    Problem lang nung nung unit ko is merong mahabang scratch sa right rear passenger side window nung nirelease siya from dealership. Naiisip ko na Baka dahil sa pagkabit ng tint kasi mukhang dahil sa cutter yung scratch. Good thing they will replace the window pagbalik ko after a month.
    Sir san nyo nakuha unit nyo po?
    Looking for 2019 rs model pero till now wala pa daw sa sta rosa at alabang. Looking forward for your reply po. Thanks
    Jun 2016
    #3624
    Any thoughts on Civic 1.8 S or E as a family car? Torn between this and the Rush, will also be driven by my wife whose height is only 5'.
    #3625
    Quote Originally Posted by reiman13 View Post
    Kahit yung lowest trim model ng Civic is much better than the Rush. If you want to be practical, even the mid level trim of the City will do for a family car, assuming 5 or less lang kayo.
    Jun 2016
    #3626
    Yes sir, lowest trim lang talaga yung target either S or E. We currently own 2013 Vios and 2016 Swift, gusto na namin i dispatch yung Vios and upgrade. I prefer the Civic because of the comfort, ang hirap lang iconvince ni esmi kasi low ground clearance daw and petite pa siya.
    #3627
    I suggest that you bring her to the showroom and let her check out the Civic. It is much better if you can ask for a test drive. Si Jut nga dinala yung Civic nya sa Sagada.
    Tama yun na dispose nyo yung Vios and get a much more comfortable car.
    Jul 2019
    #3628
    Quote Originally Posted by yitori View Post
    Sa Honda Makati ko po nakuha unit ko. Yun kasi malapit sa bahay. Almost 2 weeks ako nag antay since by order siya. Mga mid June ako nagdecide sa unit na platinum white pearl.
    Siguro by order din hanap mo kasi dami parin kasi akong nakitang stock sa dealership ng 2018 RS Turbo both sa Makati at Kalookan e.
    Sir Jut - ok na po pala yung sa shift knob. Nahanap ko na yung part number. Salamat po.
    Aug 2015
    #3629
    Honda Rizal/Cainta- along Ortigas Ext.
    Jun 2016
    #3630
    Thanks a lot po. I will try to call them later po.
    Salamat ng marami po
    Jun 2007
    #3631
    Oh, my bad. So it was actually a limitation on the driver/passenger's device (due to the unavailability of the app) as opposed to the capability of the HU.
    In addition to what sir jut said, the 2016 1.8e supports the android and iphone carplay by default, but based on the specs on the 2019 1.8s which i checked in the comparison today, it doesnt support now. Better to check na rin sa dealership.
    Aug 2016
    #3632
    Driver height not much of an issue. Wide range of seat and steering wheel adjustment. Ground clearance is not an issue either. Mas sayarin pa nga pag po pa-syete nyo approach ang ramps and humps. Approach with reasonable speed, of course, as the dampers are tuned for more comfortable (aka soft) damping but react well enough in high speed maneuvers to limit body roll.
    Aug 2016
    #3633
    Will there be a concern during warranty when using aftermarket filters (air and/or cabin)? I know we can put back the OEM filters but just want to check
    From experience, possibly YES. They can note it sa service history. What I do is remove (and clean if needed) the genuine ones (cabin and engine filters) and just install them back right before servicing. Personally using k&n cabin and engine filters.
    Aug 2016
    #3634
    Quote Originally Posted by CARLOver17 View Post
    So update... Sa initial inspection sa service center, nakalagay: check battery, for computer diagnostics, at check for possible “wires eaten by rats”.
    I was a bit surprised with the last one, and upon checking online, sobrang daming cases nga overseas ng “wires eaten by rats” sa Honda models na naglead sa multiple warning light indicators.
    I also mentioned the faulty alternator possibility para they can check. After inspection and diagnostics, ni-reset yung computer, and all the warning lights were gone. Have driven it for around 15 minutes, so far ok naman. Was told by the service agent na may possibility na bumalik yung warning lights, so stay on guard lang muna.
    Scheduled a more thorough check for Monday since may findings sa computer diagnostics sa ABS module. Not sure pa if related.
    Wala na po kayong problema sana by now.. Anyway, hindi lang po sa honda maraming nabibiktima ang wiring harnesses ng rodents, pati sa ibang makers since the law of using soy-based wiring insulators have to be used (damn environmentalists!). I had wiring insulator damage after not using the civic for more than a week, luckily nothing was severed but some spots were chafed. Did the re-wrapping myself with electrical tape and additional insulator they use on residential wirings (cloth like, maybe asbestos-based) .
    Also experienced the christmas tree warning lights incident but was solved by changing the original battery. Installed a bigger battery with some minor fitting adjustment.
    .. That was an interesting week for me
    Apr 2011
    #3635
    may naka kuha na ba ng civiv 1.8e 2019 dito ang tagal e 1month na kami nag hihintay
    Aug 2015
    #3636
    Quote Originally Posted by cjchoa View Post
    Yes, from Honda Rizal - Ortigas Ave Ext
    Jul 2019
    #3637
    Yes Sir. 2 weeks ang turnaround time before I got my unit. Sa Honda Makati ako nakakuha ng unit.
    Apr 2014
    #3638
    I assume your family doesn't need 7 seats since you're considering the Civic as an option. Aside from the Rush's 7-seater capacity and higher ride height, it doesn't really offer any significant advantage over the Civic. The Civic has better fit and finish, a more powerful engine, a more comfortable ride, and impeccable handling. Not sure about fuel economy, but seems like the Rush's body is too heavy for its 1.5L engine, which could mean negligible difference between the two (don't take my word for it, though!). As for reliability, Honda is at par with Toyota, and maintenance for the former is only every 6 months, which means less time spent for visits to the casa.
    Your wife should be able to drive it just fine -- my mom is the same height as her, and she doesn't have any troubles driving my Civic.
    If you could spring for the E variant, I say go for it. The additional features over the S will be worth it in the long run.
    Apr 2014
    #3639
    Anyone else who's had their fender light bulb replaced already? Just discovered that the light on the driver's side is already busted. Civic's 11 months old pa lang... Is it advisable to wait for my PMS and have this done at the casa since the next maintenance is just less than a month away or is DIY better?
    #3640
    Quote Originally Posted by justin_ View Post
    i don't honda, so i do not know if this bulb is a special bulb or just any old bulb... whether it is DIY-able or not.
    my guess is, it is.
    if DIY-able, it is cheaper to diy it, than to let casa do it. casa bulbs anywhere are very expensive.
    peruse your owner's manual po, if it is DIY-able.
    good luck.
All New 2016 Civic
