Results 11 to 20 of 51
June 10th, 2013 05:02 PM #11
June 10th, 2013 06:51 PM #12
- Nov 2011
- 473
June 10th, 2013 07:46 PM #13you should have honked your horn till this ignorant driver wakes up on endangering other motorist on the use of his glaring rear fog lights on clear weather...
it is only legal to use the horn to avoid an accident, and this is a impending accident because cars behind him/her is blinded/annoyed of his foolish driving using the rear fog lamps on clear weather...
BTW: welcome to the gates of HELL
June 10th, 2013 08:09 PM #14
What's new?
It simply goes to show how there are a lot of clowns out there pretending to be expert drivers.
June 10th, 2013 08:35 PM #15
Sayang naman daw kasi yun feature kung hindi din magagamit
Pero Ako guilty din dito kasi pag sa hiway, C5 or may long drive papuntang probinsya gamit ko ito pag madaling araw na
Pero sa city na laging traffic, never did
Sent from my GT-P1000 using Tapatalk 2
June 10th, 2013 08:42 PM #16
Nakakainis nga yung ganito. Ideal lang to gamitin sa city kung talagang sobrang lakas ng ulan, instead of using hazard lights which is wrong anyway. Naninilaw ako ng ganito at talagang tinututukan ko, same with sabog HIDs on HLs.
Sayang nga naman raw kung di gagamitin. Eudm yo!
June 10th, 2013 09:21 PM #17
Saka ko lang binubuksan ang RFL ko pag may nakababad na naka-high beam or HID na sabog sa likod ko. I use this on expressways especially sa two-way Startoll kapag kaunti or ako lang ang nasa daan. Kapag may nakita na akong nakabuntot sa akin, pinapatay ko na agad.
June 10th, 2013 09:27 PM #18
Dapat pag less than 100m nalang visibility bago gamitin ang rear fog. Pag clear and weather, kahit highway/expressway pa yan, dapat hindi ginagamit. Same logic lang naman yan sa high beam. Hindi porket nasa expressway dapat naka high beam. Road courtesy nalang din.
Pero uso kasi sa atin mga naka euro setup. Hindi kumpleto ang setup without rear fog. May nabasa pa ako sa kabilang forum, naka on daw parati rear fog niya para makita siya nung mga nasa likod niya. Lahat ng tao pati moderators and admin nag agree pa sa kanya :hammer:
June 10th, 2013 10:19 PM #19
Member ka ba ng autoeuropa?
Way back in the 80's, nauso yang flashing strobe light. Once you step on the brakes, the strobe light flashes. Depends on where you put it. If I find a similar item today, I'll retrofit it sa likod ng mga kotse ko. Pansensyahan nalang sa mga mahilig mag-HI ng ilaw dyan.Last edited by lowslowbenz; June 10th, 2013 at 10:23 PM.
June 10th, 2013 10:22 PM #20
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
