Results 1 to 10 of 17
- Nov 2002
- 179
September 16th, 2003 07:11 PM #1has anyone tried this....
anong mangyayari pag tumatakbo ka ng 60kph...then you turn the engine off...
anong mangyayari?
hehehehe
September 16th, 2003 07:46 PM #2
front wheel drive, manual? malamang taob ka.
rear wheel drive, manual? engine brake lang, kaso sigurado kawawa tranny mo.
A/T tranny front or rear wheel drive? pwede masira tranny mo.
- 114
September 16th, 2003 08:00 PM #3Did this one before [accidentally] sa van ng auntie ko [automatic]. The key had a long key-chain and I was stumping my leg sa tune sa radio and tinamaan ko. The ride started jerking and I was wondering why. Then I looked at the key and it was turned to off. We were at 70mph at the time. Wala lang, I went all the way to stop, put it to neutral then go again. Pero sabi ng cousion kong mechanic, I could have just put it ot neutral daw without stopping totally and I could have just turned the engine back on.
September 16th, 2003 08:16 PM #4
happened to me once...
although nag loose lang ata battery connection...
pero ginawa ko is neutral then start the engine... ayun... oks na!
- Nov 2002
- 179
- Jan 1970
- 396
September 17th, 2003 07:07 PM #7something like this happened to our van before. the engine just died while cruising, so in a way, parang turning off the key/ignition na din. the van had power steering and brakes. so when the engine died, pati power steering and brakes, nawala din. when the steering goes, mahirap na mag steer, and when you're unlucky enough to lock the steering going 60kph.. well you imagine the rest. buti na lang i was just going 30 or so in an open road.
September 18th, 2003 11:38 PM #8
delikado yan maglock yung steering wheel mo. diba yung mga oto ngayon pag tinanggal yung susui tapos try mo turn yung steering wheel mag lock sya.
September 19th, 2003 08:52 AM #9
pero yung ibang A/T hindi mo matatanggal yung key
pag wala sa "P" yung kambyo mo..
September 19th, 2003 10:03 AM #10
hahaah aba napapaisip na tuloy ako magpatakbo ng mabilis eh hehehe... pero bat un friend ko honda civic un eh namatay bigla un car while cruising wala naman meron, taka lang sya bakit d na humaharurot hehe.. tsaka umilaw un red na indicator.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
