Results 1 to 10 of 16
- Sep 2011
- 81
December 9th, 2011 02:01 PM #1hi .. bagong driver po ako and i'm using manual car. medyo lito lang ako sa driving kaya may mga tanong ako.
naka 2nd gear ako..then i'll make a full stop so i'll slow down as in very slow. the moment na nakahinto na ako don lang ako magprimera kung tatakbo na ulit yong mga sasakyan sa harap mo o neutral naman kung di pa tatakbo. correct po ba?
puwede rin po ba gawin yan pagnaka3rd gear o 4th gear ka?
December 9th, 2011 02:20 PM #3
usually pag nag-full stop ka, start ka ulit sa 1st gear, whether you're in 3rd or 4th gear previously.
- Sep 2011
- 81
December 9th, 2011 02:43 PM #4so ibig pong sabihin kahit naka3rd or 4th gear ako, i can also make a full stop by just slowing down and without downshifting while slowing down til i stop? mukha po kasing kumportable ako sa ganon paghihinto ako sa red light o kaya nakahinto mga sasakyan due to traffic. yong iba kasi what they do is that when in 3rd gear or 4th gear, they slow down and downshift (perhaps down to 2nd gear) before they stop. so puwede rin po pala yong kahit na walang downshifting while slowing down when in 3rd or 4th gear to make a full stop?
December 9th, 2011 02:53 PM #5
depende kasi rin sa situation. kung matagal yung yung pag slow down mo, let's say from 80kph, then nag slow down ka ng medyo matagal, dapat nga mag shift gear ka nga to a lower gear while moving slowly. kung hindi, parang mamamatay o manginginig yung engine mo.
or go neutral na lang then glide to a stop. from full stop, 1st gear ulit.
- Jan 2008
- 4,726
December 9th, 2011 04:56 PM #7kung gusto mo yung mala racing car style... say from 180kph eh you need to slowdown, pwede ka mag down shift to use the engine brake... tapos kung kulang pa down shift ulet... pero kung from 180 eh stop na yung sa harap say a red light then dapat mo gawin is engine brake tapos kung ang speed mo nasa 20kph na pwede ka na mag neutral to brake to stop...
take note na hindi mo din maipapasok agad sa 1st gear ang transmission lalo na kung umaandar ka pa.. dapat talaga full stop to engage 1st gear...
December 9th, 2011 05:20 PM #8
Lahat ng sinabi mo pwede, depende sa situation...pero magaral ka pa muna mag drive ulit
December 9th, 2011 05:44 PM #9
December 9th, 2011 05:53 PM #10
Nag try sa suking Shell. 300, Mits oil filter sa Banawe 1700+, Shell hx7 350, change oil 750,...
All new Mitsubishi Expander MPV!
