Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    #21
    Quote Originally Posted by pyramid00 View Post
    i saw a diy on how to change the batt. why change it? these batteries could be charged. charge it instead. let an electronics technician design a charger made from parts bought entirely from raon? the parts are; LM317 variable voltage regulator, a couple of electrolytic capacitors, etc.
    a lithuim battery can be charged up to a max of 4.2vdc. it is to be plugged in the cigarette lighter for 2-3hrs. if you forget to unplug it, no harm done. oopppsss, because of this reply, mawawalan ng sales ang mga battery stores. cost of parts p100-p200. cheap, no?
    are all lithium batteries rechargeable? or only those marked "rechargeable" ?
    Jan 2014
    #22
    Pano Kung ipa replace sa kanila how much kaya? Eh 999 pesos Epass ngayon promo nila?
    Posted via Tsikot Mobile App
    Jul 2013
    #23
    nagulat ako sa tanong mo, dr. d; wala pa akong nakitang lithuim batt na nonrechargeable. by common knowledge, mercury batt should not be charged, at pati alkaline batt din. n-c batts are rechargeable, etc.. a cp batt is similar to the batt of epass. p999 na ba ngayon ang promo price? baka more or less, p100 ang charger, the parts are installed inside a cigarette lighter plug. i would prefer the setup w/ a charger, of course, sa iba, bulky-looking ito. kung kailangan ipost ko ang schematic diag dito, sa next reply na lang. tatapusin ko yong thread about gtoil. page 30 na ako. informative na, komedy pa. hehe
    Mar 2005
    #24
    Just get the voltage and amperage of the current battery
    You can then buy any battery like it
    Just get the same amperage or current or higher not lower.
    Jan 2003
    #25
    Quote Originally Posted by jasonub View Post
    The battery cost of the same type is 1,600 at Festival. Better to buy a new epass.
    Nov 2014
    #26
    Quote Originally Posted by macsd View Post
    The new epass units have a contract of 3 years, so it's like 1,600 every 3 years. I own the old unit, which is now conking out after 12 years, so I'd rather have the batteries replaced. However, if they're phasing out the old units, then that's a problem.
Replacing the battery of the E-Pass
