Results 121 to 130 of 142
May 7th, 2021 07:30 PM #121
Best also if you can train your left foot to step on the gas too, really useful later in life when you have gout in your right foot [emoji38]
Sent from my Mi A1 using Tsikot Forums mobile app
- Dec 2019
- 2,073
May 7th, 2021 09:55 PM #122
May 7th, 2021 10:09 PM #123
Only in emergency situations where I used my left foot on the brakes when driving an automatic car. Even when I am driving spiritedly, I just use my right foot for both pedals.
I do use both foot when driving a go-cart. I love driving a go-cart.
- Nov 2019
- 1,406
May 7th, 2021 10:49 PM #124I did this when I forced myself to drive even if wala pang experience.
I thought this was the proper driving until I saw someone how his right foot move to gas pedal and back to brake.
But sometimes may use din ito.
Sa inclined roads when I was stuck in the middle na medyo nakadikit sa akin ang sa likod, when I press brake to stop and to prevent bumping the rear, I slowly move my left foot to brake pedal.
When its on a comfortable position na, I now move my right foot to gas pedal.
So when its time to accelerate, nakaprepare na left foot to press brake para hindi maatrasan yung nasa likod na car.
May 7th, 2021 11:01 PM #125
Done badly, that's one way to rear-end the car in front of you.
Anyway, unless it's a very steep incline, many A/Ts have hill-assist either permanently enabled or one that can be switched on. Even the old 1st gen Innova A/T has it (permanently enabled). On an incline like in a carpark building ramp, if I let go of the gas pedal, the vehicle does not slide back. Though it's still best practice to have your foot on the brakes nevertheless. However, you're assured that the car will stay put when you move your foot off the brakes and onto the gas pedal.
If it's a steeper grade, use the handbrake to hold the vehicle.
May 7th, 2021 11:37 PM #126
Precisely. Like I said, it is an added skill useful in certain situations but not something you do in normal, everyday driving. Usually, the right foot has more finess than the left but you can train it. The position is not comfortable though & the higher position of the brake pedal doesn’t make this practical. I posed this question in an international group & like you guys, there were a varying mix of comments[emoji16]
I first saw it in Youtube videos of Rallye drivers doing it & I just got curious but tried it in Star tollway. Initially, you’d tend too put too much pressure on the brake but I easily adjusted to it & used it in Lipa after. Not for the weak of heart though. If you think it’s preposterous, don’t do it is my only piece of advise[emoji16]
May 7th, 2021 11:41 PM #127
My car doesn’t have a hand operated parking brake unfortunately. Its a diesel & the torque prevents it from sliding back on an incline but there were a couple of occasions that the grade was too steep that the torque wasn’t of much help. I left foot braked instead.
May 8th, 2021 12:22 AM #128
- Jan 2007
- 2,585
May 8th, 2021 07:11 AM #130
^Lufet! Awesome pedal work!
Here’s another, pero full A/T with Sebastien Leob. Mas kaya pa natin ito.
Onboard Sebastien Loeb - Citroën C4 WRC - Hillclimb Turckheim - YouTube
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
