Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 142
    #41
    Quote Originally Posted by remzam View Post
    Sabi nga nila, feel the engine. Kilalanin mo kotse mo. Pag humihingi, bigyan mo. Pag sumosobra, bawasan mo. Proper shifting. Don't rely on "at X speed dapat nasa Y gear ka"
    Sent from my ONEPLUS A3000 using Tapatalk
    para namang eddie garcia ad...
    yup tama sila lahat...
    - more practice
    - feel the engine
    - shift at correct speed/rpm
    sa case ko, i always shift at 2krpm...
    Quote Originally Posted by Baltz View Post
    Guys makiki-singit lang pero usapang kambyo.
    1. What will happen if you are running at 4rth gear. Then went to press the brake. Speed drops at around 20kmph. Tas apak lang ulit sa gas?
    2.what if you are running at around 45-50kmph, brake momentarily.
    Shift to 3rd gear. Then car hesitates
    Yung bang sobrang pigil nya tumakbo lahit anong tapak sa gas. Ano po kaya ng yare pag ganon?
    Sent from my ASUS_X00DDA using Tapatalk
    1. you can slow down but the revs will drop to a point the engine will stall. if this is an evasive emergency manueaver you won't have the engine brake to assist you and it will take a while to downshift. and if you stall you might lose brake pressure and steering assist. downshift if you need to slow down.
    now accelerating from 20kph at 4th gear is called lugging. it's not good as explained by this guy
    Why You Should Never Lug Your Engine (Especially Turbos) - YouTube
    2. if the car hesitates then you're at a gear too high, downshift
    . this is still lugging...
    Sep 2006
    #44
    Doc, sino po si Eddie Garcia? Hehe
    Sep 2006
    #45
    What vehicle are you referring in the first place?
    #46
    Singit din ito. Nowadays, with the popularity of a/t transmissions, less & less people learn to drive stick (manual). The best way to learn proper driving is by stick, knowing & feeling the proper gear shifts, not by looking at the speedo or the tach, but just by the sound of the engine. Knowing when to brake then what gear to use when turning & entering a street, approaching humps (maraming namamatayan ng makina dyan), quick gear downshifts when overtaking or changing lanes. The hand-eye-feet coordination honed driving manual is a skill you can never get driving auto. It is also a skill you can use in your auto with a sportronic tranny. Don’t you know you have more control of the car in a bend with proper downshifts? How many times have I gotten myself out of potential trouble using proper braking, gear changes & modulation of the revs with the clutch? I insisted on my son learning stick in driving school & his friends are in awe.
    #47
    Si Manoy.
    BTT. To add, different vehicles have different dynamics depending on the condition of tyres, thickness of brakes, gearing of tranny, engine performance, suspension ride quality, steering feel& ergonomics of controls. Practice and mastery of these dynamics lets you adapt to the car making it like part of your body whenever you drive it. Try switching cars after another..after another, and you'd know what i mean. There is also this saying that "a good driver is also a mechanic" which means the driver understands how the machine works..
    Feb 2012
    #48
    1. At 20kph, even nasa kalsada ka na slightly sloping downwards, medyo kelangan mo na mag-shift to 3rd gear kahit momentarily lang just to get the car up to speed para maka-shift ka sa 4th.
    2. At 50kph dapat wala na masyadong hesitation at 3rd gear. Check your engine or transmission condition.
    Mar 2018
    #49
    Quote Originally Posted by gearhead000 View Post
    Boss ano po mang yayare if nasa 4rth gear ka tas nag preno ka onti pero mabilis parin arangkada tas bigla kang nag down shift sa 3rd?
    Yung sa sentra ko na 97 kasi kabisado ko pasok ng kambyo.
    Yung sa almera ko ngayon medyo nalilito ako sa makina nya. Parang di kami nagkakaintindihan.
    Thanks for your input
    Jun 2012
    #50
    Pakinggan mo lang makina. Know when to shift. Kahit anong car na dala mo, no need na sumilip sa rev and speed
    Mar 2018
    #51
    Quote Originally Posted by dct View Post
    Oo nge sir eh. Sa dati ko madaling maramdaman yung makina. Dito sa bago medyo mahirap pa eh. Siguro sanayan lang. Madalas ko na ipapasok sa engine break eh . Hahaha
    Neway sir pano po ba umarangkada uli pag aksidente ako na pa engine break. Madalas kasi sa 4rth gear naibaba ko sa 3rd tas yun na engine break na tas di na makaarangkada abala na ko sa kalye.
    tingin ko din, factor din dito ang engine size and weight ng vehicle, it varies from 1.4 to 1.6 engine, turbo or n.a... gas or diesel... tapos if driver lang sakay or with passengers... and ang kaha din ng sasakyanan...
    havent tried 1.4 mt na engine... ni aavoid ko ang half clutch driving pag di talaga need, either down or up gear depende sa situation...
    #53
    Sabihin natin scenario ganito: galing ka Quirino papunta sa Magallanes. Maluwag naman traffic kaya takbo mo 60 at 4th gear. Since may motor, truck o kung ano man obstacles, unang gagawin mo ease off pedal para mag engine BRAKE tapos step on the brake then clutch, down shift to 3rd or second, depende sa bagal mo then accelerate na. Pwede rin i-delay mo upshift ng gear para higher ang rev mo at mas madali ka maka accelerate, yun lang nga, mas malakas sa fuel. Ako minsan, halimbawa nasa 5th, down shift 4th then BRAKE at kung yung speed bumagal pa, shift 3rd, ease off pedal then accelerate ulit while nilalaro mo yung clutch para di mag lug engine (par lang mabilis mag accelerate), then kung open na road, upshift na. Practice lang, iba iba style ng drivers.
    #54
    practice.
    practice makes perfect.
    there ain't no substitute for practice.
    Mar 2018
    #55
    Thanks for the tip sir. Try ko yan papuntang tagaytay.
    Mar 2018
    #56
    Salamat samga tip sirs hehehe.
    #57
    At habang nag pa-practice ka, laging tandaan ang mga ito:
    1. ang left lane para sa pag overtake at mabibilis na sasakyan
    2. Lagi mong papansinin ang side at rearview mirrors mo. Kapag nakita mo na maraming sasakyan na naka buntot sayo, hindi ibig sabihin nun nagagandahan sila sa sasakyan mo. Ang ibig sabihin nun, masyado kang mabagal at dapat mag bigay ka.
    3. Manatili sa lane mo at wag kang gigitna ng dalawang lane (road hog)
    4. Ang hazard light ay pang emergency lamang, hindi ginagamit kapag umuulan.
    #58
    Dagdag ko lang.
    1. Give way to emergency vehicles:
    - Ambulance
    - Fire Truck
    - Police Cars , Bikes
    (And dont follow them na kunwari kasama ka)
    2. Always stop before pedestrian crossings & yellow boxes (even if others dont)
    3. Always give way to a pedestrian once he/she started to cross inside the pedestrian crossing.
    4. Use your turn signals 15-30 seconds before you actually make the turn. (Hindi yung kung kelan paliko tsaka lang sesenyas)
    5. If you really need to stop or drop off somebody at a busy road, look for a place that will give less inconvenience to other motorists. (Hindi porke naka-hazard ka wala ka pakialam sa iba)
    6. On expressways. Follow the speed limit and get out of the damn overtaking lane!!!!
    7. Dont use your hazard lights when the rain is heavy. Because we cannot tell if your turning left or right. Your headlights are enough for us to tell that you are there.
    8. Always gesture (with a smile) to the driver that let you in their lane as a sign of appreciation. (Pinagbigyan ka niya. Huwag feeling entitled).
    Sep 2006
    #59
    Dagdag ko lang.
    Number 1 dapat ito. Andami pa rin idiot na gumagawa nito. Parang dependent sa steering wheel yung turn signals ng mga hinayupak na mga ito.
    Nov 2014
    #60
    Can I add--what with the roadworks everywhere--
    Merge alternately on zipper lanes. Kapag magna-narrow ang kalsada sa mas konti na lane, salit-salit kayo dapat sa pag-merge. Pet peeve ko 'to eh, yung mga feeling iniisahan at sinisingitan kapag nagtatry ka na lumipat sa natirang lane.
Proper Driving
