Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 89
    Maybe the OP is a proponent of self driving cars.
    Apr 2008
    I have been involved in my fair share of accidents and near-accidents before. And in my experience, the first and only reaction is to step hard on the brakes. In such situation, I was unable to consider turning the steering wheel or anything else to avoid collision since it all happened very quickly.
    Sent from my SM-G900I using Tapatalk
    ^That's very deadly without the aid of an ABS..
    Apr 2008
    True that. I was driving the Revo one time and it was raining when the jeepney in front suddenly stopped. I was unable to decelerate in time and hydroplaned, hitting the jeepney's rear end, hence the accident.
    But then when in a state of panic, slamming the brakes was the only thing that registered in my mind. On retrospect, I would have been able to avoid that accident had I quickly changed lanes.
    Hence, the kasabihan na "wag kang TUTUTOK", especially if mahina ang preno mo..
    To prevent is better than to cure but sometimes, accidents just happen. It's a miracle though that we are still alive if it was a deadly accident that we got involved in.
    Apr 2008
    Yep. Can't explain why I was somewhat out of sorts that day, hence the delayed reaction. All of our cars have ABS now and its a really nice thing to have, though thick and grippy tires are at least just as important, if not more.
    But then again, point was that under panic autopilot mode, the reaction I had was to step on the brake pedal and not the gas pedal. I really could not understand how some people mistake the brake and gas pedals, even if it was in a state of panic.
    Probably, because those people who are used to or only drive an a/t use their two feet separately in accelerating and braking their car? Which also explains that the brake pedal on an a/t is wider than the one on a m/t. It also makes me wonder if manufacturers or driving schools lectured drivers about using those two pedals properly.
    But sometimes, no matter how modern a car is, especially those with safety aids, if stupid drivers still exist on the roads, then there's really no hope to prevent it at all. That's why I despise them so much. Every day, you will always encounter them if you go out of your house to work or go somewhere daily.
    Quote Originally Posted by BOBOJut703BOBO View Post
    Just like you!
    Bro palitan mo naman ang handle mo, please.
    Mods, maybe you could do something here. TIA.
    Jul 2015
    Anyare???
    Dec 2013
    Imho, sometimes sh*t happens. Kahit pa ikaw ang pinakamagaling magmaneho sa mundo accidents do happen. Kaya nga accident. No rational person would knowingly and intentionally crash their car. Sa pinas pa na major purchase ang sasakyan, di naman disposable ito na ibabangga lang. No driver education/proper implementation of rules/etc could ensure that this won't happen anymore. If say you've driven all your life ex 20 years tapos malinis record then had an accident, tangang driver ka na? Ridiculous.
    Just to have a proper perspective, maybe it would be nice to look at the number of accidents due to pedal misapplicarion vis a vis other causes of accidents vs the total number of trips kahit sa metro manila lang (kahit for automatics only). I doubt if it would be a significant number...
    Wow what a name. Kabait ni jut may magalit pa.
    isa siguro sa nasita nya.
    btt: ang error ko lang while driving AT ay yun naka reverse pala ako coming from stop and go traffic. buti nalang yun nasa likod ko di naka tutok sakin, plus sa brake pedal nakapatong yung paa ko nung naramdaman ko umatras.
    When I was starting to drive an automatic, medyo kumakadyot din talaga preno kasi nga sanay ako sa manual na may clutch.
    well, technology has improved.
    ATs don't kadyot much anymore, when their brakes are applied.
    Dami nakakatulog, nakainom tapos sisisihin ang barriers wala daw ilaw🤪
    There are still a few stupid drivers who are driving drunk or intoxicated. On Friday or Saturday nights, I observe these idiots driving slow or veering off the lanes at SLEX and sadly on the subdivision streets of BF Homes.
    One safety advantage ng m/t it will engine brake once makatulog and mabitiwan ang pedal. Sa a/t wala! at high speed free- wheeling na pra kang nasa duyan[emoji15]
    One safety advantage ng m/t it will engine break once makatulog and mabitiwan ang pedal. Sa a/t wala! at high speed free- wheeling na pra kang nasa duyan[emoji15]
    Pansin ko, it depends on the transmission logic and some other conditions... so it differs from car to car.
    Not all automatics are the same. The new ones will drop its rpm and slow down.
    DCTs behave more like MT which is very dependent on how you apply pressure to the gas pedal. CVTs will do rev matching.
    Right, but mabibilang sa daliri naka dual clutch na hindi mura ah. I’m referring to those common a/t’s and some are 4at pa.
Nakakatakot ba talaga ang automatic?
