Results 1 to 10 of 24
turbo
- Nov 2002
- 503
November 18th, 2007 08:09 PM #1This is the fourth Eleanor the I made.
This car belongs to Wesley Gatchalian. All conversion is done with guage #16 BI sheets.
He opted for a 289 engine with slight tweeking. The car has front disc and rack and pinion steering. Wheels are 18".
http://www.flickr.com/photos/81856035*N00/2043301684/
http://www.flickr.com/photos/8185603...n/photostream/
http://www.flickr.com/photos/81856035*N00/2042500933/
http://www.flickr.com/photos/81856035*N00/20424987Last edited by turbo; November 18th, 2007 at 08:11 PM.
November 18th, 2007 08:48 PM #2
Dang that baby looks clean!
Do you use some special metal bender? Does the process take longer than fiberglass?
BANNED BANNED BANNED
- 3,790
turbo
- Nov 2002
- 503
November 18th, 2007 09:08 PM #4Ooops, double posts.
Sorry!Last edited by turbo; November 18th, 2007 at 09:17 PM.
turbo
- Nov 2002
- 503
November 18th, 2007 09:13 PM #5No special benders.
Actually yong un kong ginawa ang gamit ko cardboard lang. just to get the proportion.
Meron ding putty, pero not thick. Every weld mus have putty.
The main advantage of the metal conversion is that connections will not show hairline cracks after sometime. Fiberglass to metal will eventually crack after some exposure to heat and cold. And will also exhibit hairline cracks in the gel finish.
The metal, if properly prepared will last a life time.
Since the metal is formed and welded into place. It will take a lot longer to complete that a kit. But kits even coming from the US has some "fitting problems".
Fiberglass hood and trunks usually have fitting problems and stress cracks after some "open-close" cycle.
November 18th, 2007 11:40 PM #6
It takes a lot of super-precise skill to make those tires not rub against the wheel well like that. Wheel travel is tricky to just estimate. I guess you also did underbody strengthening.
Does it have the 350 Windsor engine block?
turbo
- Nov 2002
- 503
November 19th, 2007 06:00 AM #7It still has a 302(not a 289 that I previously mentioned).
I cut the old fender(using reciprocating saw) then had six oversized men(hehe) jump up and down in the trunk to simulate suspension travel. When proper clearance was achieved, I welded the fender flares to the fender. Now it won't rub.
My personal Eleanor is a lot more radical, though it will take some more time to finish. hehehe.
http://tsikot.yehey.com/forums/showt...light=corvette
November 19th, 2007 07:18 AM #8
Nice!
OT: I watched the original Gone In 60 Seconds released in 1974. I seem to like it better than the remake by Nicolas Cage, et al. But that's just me.
November 19th, 2007 08:55 AM #9
wow, that looks like it came from the factory!!
except for one small detail - sorry to nitpick, but is the upper part of the hood misaligned?
but that bodywork looks very close to perfect....especially the lights which can be a pain to align like that
November 19th, 2007 12:14 PM #10
Long time no see!
And... great work! I can't imagine how many man-hours that took!
What happened to this place kaya? I remember they launched with a bang. Celebs pa and all that.
Hybrids and EV
