Results 1 to 7 of 7
January 26th, 2003 09:45 PM #1
I saw the exhibit of the 2003 Subaru Forester kanina sa Shangrila mall. And I was made curious by on of its features:
HORIZONTALLY OPPOSED ENGINE
Sabi nung taga GM, mas fuel efficient daw ito and mas malakas ang makina since it defies the laws of gravity daw dahil patagilid na ang takbo ng mga pistons imbis na diagonal ang set-up nito. Is this true? Galing!!! :shock: Bakit ngayon lang naisipan to???
Anyways...curious lang po... :roll: :roll:
Here's the price nga pala: P1,310,000 for Manual
P1,360,000 for Automatic
January 26th, 2003 10:09 PM #2
djerms::: pare boxers have been around for quite a while. Posrsches and subaru are the main proponents of these types of engines. "Defy gravity?" i dont think so. :D
Boxers, being shorter in height compared to inline or V engines, give the car a lower center of gravity, improving handling characteristics (well, in general at least). I think this was what the salesman wanted to say. If a boxer engine defied gravity then, well heheh, we'd have flying subarus :D
January 26th, 2003 11:13 PM #3
the boxer configuration by itself won't give any appreciable fuel efficiency and power benefits... what it does affect is center of gravity, and noise, vibration, and idle quality probably
basically, the salesman is BSing you, imo
January 27th, 2003 01:29 AM #4
Djerms,
Yung diagonal set-up, Vee configuration iyon. V8, V6, B12, etc. Iba-iba din ang angles niyan. May 90 degrees, 60 degrees at kung ano-ano pa. Yung makina natin sa Trooper at Pajero ay in-line configuration meaning patayo ang mga piston as in up and down ang movement (wow, kinky! hehehe).
Yung boxer engine nakahiga ang pistons. Kung makikita mo in action parang side to side na ang movement niya. Ginagamit din ng ibang manufacturers iyan like Porsche.
Yep, it will lower your center of gravity. NOT defy gravity. hehehe.
- 22
January 27th, 2003 03:03 AM #5Yup. Exactly why it's called a boxer engine because of its horizontal "boxing" motion.
- 290
January 27th, 2003 10:24 AM #6checkout howstuffworks and you'll see there different types of engines. the horizontal thing isn't new at all.
January 27th, 2003 11:30 AM #7
while youre at it, check out Volkswagen's W-engines (double V). More cylinders, less engine mass.
Yup, experienced it myself as well. Maybe we can summarize what's been said (oj88, Dr.Kamiya...
Liquid tire sealant
