Let me just clarify that module lines are complete even without the update. I still have the old codes and I was confused why my as-built files are not matched with my actual codes. Turns out I have a corrupted download of AB files. I re-downloaded the AB file and they do match apparently.
Sent from my GT-I9505 using Tapatalk
As what my SA says, SOP ni ford PH is, if walang problema oto(no check engine light, no errors or issues with operating your car, with they won't touch your car, including the updating of modules. Something like if aint broke, dont fix it mentallity, which is fair naman.
However, if you have an access in ford IDS, you will see that there are "some" updates to modules to further improve its operation, "fix" some minor issues, etcetc.
Hi guys. I'm just new here. Anyone successfully activated TPMS on Trend 2017? Is it possible on trend or only for titanium? I have tried it but it displays that tire pressure warning on screen so I just disabled it. Thanks
Btw here are some modifications that work on my trend.
- Silent Mode
- Off Road Guage
- DRL control on vehicle settings
- Aircon Control
bro nag lagay ka ng tpms transmitter modules na compatible?
Hindi paps. Although may workaround dyan sa TPMS issue. Pwede mo ma-view yung values sa android phone if you have a compatible bluetooth OBD2 via Torque app.
Kung may tpms yung Trend same as with Ti then pwede. Although a cheaper and easier option would be to buy tpms devices on Lazada. Kasi bibili ka pa ng obd2 scanner, tapos you need the Torque Pro app which is not free din, then you go to the hassle of configuring yung built-in tpms ng Everest para bumato sya ng signal sa phone.
3-in-1 fuel economy display
IPC - 720-04-01 - from 2003-0080 to 3003-0080
sir is there any other code and feature that i can try with my trend? I only tried drl on/off menu. Thanks
Activating apim for rear camera.
Yan sa tingin ko pinaka usefull
Sent from my SM-A720F using Tsikot Forums mobile app
Some hacks from last year that I forgot to post.
Sync 2 equalizer
APIM - 7D0-01-02 - from 000A 0200 to 000A 0A00
Driver's climate control
IPC - 720-05-01 - from C068 0202 to E0A8
Power distribution
IPC - 720-07-01 - from 8401 0000 to 8401 8000
IPC - 720-07-02 - from 0364 0097 to 0314 0097
