Has anyone turned off ung bulb outage sa BCM para you can change your signal lights to LED? Para no hyperflashing? Anyone tried that na? Gusto ko kasi palitan to LED ung signal lights eh.
https://www.google.com.ph/url?sa=t&s...L8hb0542ssa9T2
Yes po sir. You need the 4dtech harness. If you want oem style reverse cam, please search sa ebay or aliexpress ng trajectory camera, it includes all the cables needed pwede nyo po pakabit sa suking auto shop, then pwede po kayo pa enable sa may mga elm327 dito sa forum kung san pinaka malapit sa inyo if you dont plan to buy elm327. Btw saw elm327 selling sa lazada around 700 pesos ata then you can enable it yourself.
During a SYNC3 V3.0 update, I received a SIGN_ERR01 pop-up. I removed the USB and cycled the ignition. After turning the ignition on, the screen did not turn on, audio power can't be turned on and USB did not have power supplied to my mobile (this was checked a little later). Rear view camera display does not work anymore when in reverse. Basically no power to my head unit. Manual switches for the temperature and fan still work. Checked all fuses under the dash to be ok. Removed negative battery cable from the terminal and reconnected after 30 mins but with no change. Ran FORSCAN and did not find anything wrong (no DTCs) except when I tried to do the APIM diagnostic test which could not proceed and threw the error "the vehicle conditions are incorrect." Should I bring it to the dealer already?
bios or firmware updates are very critical. hope you didnt brick your sync system..
Actually what started it all was to try to change SYNC3 Home screen with the bigger NAV (leftmost instead of small top right) but encountered "NAVIGATION FAULT - navigation was lost". Reloaded original AS-BUILT settings then flashed v2.3.16284 1.1.1.806 (only NA version available) in the hopes to load the map but still encountered NAV FAULT. Flashed to v2.2.16132 1.1.1.80 to finally clear NAV FAULT and everything was ok except that map was 2015 ver (i think). Flashed v2.3.16284 1.1.1.806 again and retrieved original map ver. Flashed v3.0.18025 25.01.2018 to update versions and map but map ver was still the original one. I got ahold of the latest map ver and added it to the v3.0 package but encountered the SIGN_ERR01 and then the blank screen after recycling the ignition switch.
Lesson learned - not to fix what aint broke![]()
Guys, help naman can you share what is the range of boost pressure of the 2.2 engine. From idle to almost redline range of MAP reading..thanks appreciate the feedback. Also if you could share the fuel rail press.. I still dont have the forscan and the elm..thanks.
Wala naman sir, medyo napapaisip lang ng project...recently browsed un devil's Own Water/methanol Injection naging interesado ako kase it claims a cleaning inlet manifold as a benefits aside sa 10-15Hp gain daw...Now I need to know ang typical discharge Turbo pressure na reading ng MAP sa intake manifold, to select which MAP pressure switch dapat.
Hindi updated firmware ng IPC mo kaya ganyan nalabas. Need mo ipa update IPC sa casa/IDS then input mo ung codes ni ferrari.
Ive tried last time nag pa PMS ako sa Alabang..hindi daw nila update kase wala daw fault nor advice ng FORD...pina tanong ko pa dun sa Manager na expat..no need of updates daw... siempre hindi ko lang masabi na dapat me upddate for this forscan.
Anybody na may forscan code sa Everest Titanium yung 3rd row seat ko na autofold ayaw gumana sabi ng casa may fault daw ang bcm kaya nagpalit sila ng BCM pero hanggang ngayun ayaw pa rin gumana ng 3rd row seat, baka kasi na disable lang anu kaya ang code ng bcm sa 3rd row seat
Too much electronics [emoji24]
Not a FORscan hack but useful for those who want to add another key fob or two to their Everests. Two admin keys are needed for the programming to work.
I bought this blank spare key fob from eBay, it arrived 12 days later. Had it duplicated at the mall for P500.
3 Button Remote Key FSK 434MHz ID49 Chip For Ford Escort New Mondeo HU11 Blade 69633957433 | eBay
Follow the programming instruction from the video below. Count 5 seconds after each key insertion if you don't hear a chime.
I now have 3 working keys. Total cost is around P2000..![]()
