Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 141 to 160 of 212
    Feb 2011
    #141
    Sir, is there a way to disable Active Noise Cancellation sa Forscan? Thanks
    Apr 2009
    #142
    Quote Originally Posted by pobre24 View Post
    Yes, thru the Audio Control Module. Please see the link below.
    2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com - View Single Post - Modifying As-Built Data Guide
    Sent from my GT-I9505 using Tapatalk
    Jul 2016
    #143
    Quote Originally Posted by ferrarifan View Post
    The latest online brochure of Everest indicates TPMS is available only on Ti Premium variants, so you may really need to purchase one to have one.
    The TPMS for eve and ranger IPC firmware is only an "alarm."
    There are 3 ways to view actaul live data.
    1. Use forscan/torque pro custom pid to view individual TP
    2. Use other ford IPC firmware and write it to everest(vignale has individual IPC read out.) down side is that you will loose other functionalities intended for everest like power distribution and Off road gauge pitch and roll.
    3. Hope for Ford to update IPC of eve/ranger(like 2019 everest/ranger facelifts?) And re-write it to your IPC via IDS, assuming 2019 models would still use the dual 4" ipc display.
    Jul 2016
    #144
    You can also disconnect all three mics to disable.
    Apr 2009
    #145
    Quote Originally Posted by Janemar View Post
    Yes it is. That's why we were discussing option 1. I'm just confirming that TPMS for Eve (warning only) is not a feature of any other variant but Ti Premiums, so the guy has no choice actually but to buy a dedicated TPMS device.
    Feb 2011
    #146
    Thanks sir!
    Jan 2016
    #147
    good day mga sirs!
    Everest trend user here
    Nagpalit ako ng tire from size r18 to r20
    Napansin ko hnd na tama ung reading ng speedometer sa waze or sa map ko 100kph pero 105 na sa speedometer.
    Naisip ko lang if there is a way to correct using forscan?
    Thank you
    Jun 2012
    #148
    Quote Originally Posted by ebirest View Post
    good day mga sirs!
    Thank you
    Ganun sa lahat ng sasakyan. Mas mababa ang gps speed
    Sent from my SM-A9000 using Tapatalk
    Apr 2009
    #149
    Quote Originally Posted by dct View Post
    Yes. Mas accurate yung gps speed. The car manufacturers usually make their speedometers read higher than normal to prevent suits related to overspeeding incidents.
    Sep 2005
    #150
    Mga sirs, nagdagdag po ako ng climate menu and navigation sa right side ng instrument panel. Kaso bigla nawala yung oras. Naging ganito "--.-- " po nakadisplay. Baka lang po may naka experience sa inyo and baka may work around. Thanks po.
    May 2007
    #151
    Quote Originally Posted by untamed View Post
    ganyan din sa akin. after ilang days nag work ulit yung clock. baka gps related, not sure.
    Sep 2005
    #152
    May navi po ba yung sa inyo sir eido? Yung trend ko po kasi hindi umabot na may navi. Kung wala po navi wala din gps diba.
    Jul 2016
    #153
    Go to clock settings sa sync 2/3 screen. Change AM to PM, vice-versa, back.
    Done.
    Oct 2003
    #154
    *untamed,
    Navigation sa right side ng instrument panel? Any pics? Ok un ah.
    Apr 2009
    #155
    Quote Originally Posted by zechs View Post
    *untamed,
    Compass lang yun sir.
    Oct 2003
    #156
    Akala ko ung navigation na talaga. That would be nice. Haha
    #157
    *untamed,
    like this........
    Apr 2009
    #158
    Quote Originally Posted by alrorskyz View Post
    like this........
    Like this po...
    Sep 2005
    #159
    Sorry sir compass pala. Hehe
    Jul 2016
    #160
    2017 and up Navi equipped everest trend and up meron turn by turn instruction dun sa Tab na yun.
    Asked casa about it, nasa 80k aabot ung Sync 3 with navigation enabled APIM, GPS antenna and Android auto/carplay usb socket.
FORScan for Ford Everest
