Power distribution
IPC - 720-07-01 - from 8401 0000 to 8401 8000
IPC - 720-07-02 - from 0364 0097 to 0314 0097
Power distribution
Mga sirs, nagdagdag po ako ng climate menu and navigation sa right side ng instrument panel. Kaso bigla nawala yung oras. Naging ganito "--.-- " po nakadisplay. Baka lang po may naka experience sa inyo and baka may work around. Thanks po.
*untamed,
Navigation sa right side ng instrument panel? Any pics? Ok un ah.
May navi po ba yung sa inyo sir eido? Yung trend ko po kasi hindi umabot na may navi. Kung wala po navi wala din gps diba.
bios or firmware updates are very critical. hope you didnt brick your sync system..
Actually what started it all was to try to change SYNC3 Home screen with the bigger NAV (leftmost instead of small top right) but encountered "NAVIGATION FAULT - navigation was lost". Reloaded original AS-BUILT settings then flashed v2.3.16284 1.1.1.806 (only NA version available) in the hopes to load the map but still encountered NAV FAULT. Flashed to v2.2.16132 1.1.1.80 to finally clear NAV FAULT and everything was ok except that map was 2015 ver (i think). Flashed v2.3.16284 1.1.1.806 again and retrieved original map ver. Flashed v3.0.18025 25.01.2018 to update versions and map but map ver was still the original one. I got ahold of the latest map ver and added it to the v3.0 package but encountered the SIGN_ERR01 and then the blank screen after recycling the ignition switch.
Lesson learned - not to fix what aint broke![]()
Guys, help naman can you share what is the range of boost pressure of the 2.2 engine. From idle to almost redline range of MAP reading..thanks appreciate the feedback. Also if you could share the fuel rail press.. I still dont have the forscan and the elm..thanks.
Wala naman sir, medyo napapaisip lang ng project...recently browsed un devil's Own Water/methanol Injection naging interesado ako kase it claims a cleaning inlet manifold as a benefits aside sa 10-15Hp gain daw...Now I need to know ang typical discharge Turbo pressure na reading ng MAP sa intake manifold, to select which MAP pressure switch dapat.
